Latest: Stu-mill
Overall: 17131
Online Now [296]:
Visitors: 296
Today: 24950
Total: 104661224
Forums › The Car › 206 Talk › Rear washer jet
Rear washer jet
leigh_boy
PostPosted: Wed May 11, 2011 3:10 am Up
i know this sounds silly, but i loked at a few pics and i cant see that it has a washer jet on the rear like the fronts do, i have a bit of pipe sticking out of the top break light so presume its ment to be there but cant see how it comes apart so i can look at it propperly as at the min, water comes out in a staight line and not directed to the window.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Wed May 11, 2011 3:11 am Up
It comes out of the break light Smile
leigh_boy
PostPosted: Wed May 11, 2011 3:14 am Up
how does the break light come off?
*DEAD*206 Gti 138
PostPosted: Wed May 11, 2011 3:16 am Up
Open boot and two nuts behind the light, Wink
PostPosted: Wed May 11, 2011 3:18 am Up
Two bolts from the inside secure it in then it needs to be popped out, when it's popped out the washer hose just pulls off it.
Having said that I found it extremely difficult to pop out and ended up snapping mine, maybe there is a special way to do it but I couldn't see anyway to get into it.
leigh_boy
PostPosted: Wed May 11, 2011 3:28 am Up
nice 1 i will have a look at it later i was jsut going to pull it off Smile
*DEAD*206 Gti 138
PostPosted: Wed May 11, 2011 3:29 am Up
Before you undo the nuts all the way, tap the back of the ractchet/spanner so light pops out/comes loose
Then finish unscrewing nuts Wink
leigh_boy
PostPosted: Wed May 11, 2011 3:30 am Up
nice 1 cheers for the tip Smile
*DEAD*206 Gti 138
Jay794
Do you think it's possible to modify the rear jet so it acts more like a spray instead of p**sing against wall?
michaelbishop
PostPosted: Wed May 11, 2011 4:09 am Up
You'll end up mangling it like I did! Very Happy Was spraying on the road out behind me when I was finished with it! Embarassed
The Journey, The Garage,
Jay794
PostPosted: Wed May 11, 2011 4:17 am Up
I hate my rear washer jet, the timing is completely wrong with the back wiper I have to leave it spraying for ages to completely cover the window
Lewis
PostPosted: Wed May 11, 2011 5:16 am Up
i think thats the same with all of them mate, timing is so out!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
michaelbishop
PostPosted: Wed May 11, 2011 5:25 am Up
What He Said
You have to hold it down for a while before it actually does any work!! Wall Bang
PostPosted: Wed May 11, 2011 5:41 am Up
All you need is a quick twist for the rear wash / wipe, the BSI takes care of the squirting Wink
