Online Now [120]:
Visitors: 120
Today: 33225
Total: 105006163
Forums › The Car › 206 Talk › HEAD on a 55 reg...
HEAD on a 55 reg...
abs06
PostPosted: Fri May 13, 2011 3:51 pm Up
I had my oil changed today at the garage done by a friend, who now owns his own business.
Basicly, i been noticing a few oil drops on drive for a few months, though nothing of it at first, but then looked under car and saw drips of oil, asked a colluege at work, and said could be a gasket.
while it was having the oil filter and new oil done, we invetigated it, and found that it was the head that was leaking oil.
my car is a 2005 '55' and done 82k.
is this normal for the car of its age, with the milage...
also had the car on the diagnostic for free, and came back with no faults Very Happy
thanks in advance
ABDUL
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
PostPosted: Fri May 13, 2011 3:59 pm Up
Sound like a small oil leak..you sure it's not just a rocker cover gasket?
abs06
PostPosted: Fri May 13, 2011 4:05 pm Up
tbh im not sure.. its on the driver side, near cambelt
Abs
Seb
PostPosted: Fri May 13, 2011 4:34 pm Up
Staff - Seb
It might just be a rocker cover leak. Tbh a lot of cars have small leaks. I'm sure you can either get a replacement gasket or just use some of the instant stuff.
abs06
PostPosted: Sat May 14, 2011 4:45 am Up
Kwl cheers. Will get it check out
Abs
leigh_boy
PostPosted: Sat May 14, 2011 12:34 pm Up
is it comeing from the top if the head? or the bottom of the head, top will be rocker cover
bottom is head gasket
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Twidly
PostPosted: Sat May 14, 2011 2:49 pm Up
You're supposed to do that in the car, not on it. You might dent the bonnet! Wink
abs06
PostPosted: Mon May 16, 2011 5:16 am Up
From the bottom. Top is dry
Yh my mechanic said would be head
The car is a 2005 '55 on 82k. Seems odd a 5/6 year old car head would go.
Abs
PostPosted: Mon May 16, 2011 5:37 am Up
the ET3 engine is not the best engine in terms of reliability in the PSA series anway....
wouldn't be suprise if the head is gone; and surely this is not the first time i have seen in here this year.
leigh_boy
PostPosted: Mon May 16, 2011 5:39 am Up
headgasket on 206 are p**s easy
*DEAD*206 Gti 138
abs06
PostPosted: Mon May 16, 2011 6:37 am Up
Cheers everyone
Abs
