Latest: airmastertapes
Overall: 17133
Online Now [85]:
Visitors: 84
Today: 40657
Total: 106901239
Forums › The Car › 206 Problems › car reving on its own
fredwooduk
PostPosted: Mon May 16, 2011 4:11 am Up
HI THERE NEW TO THE FORUM,
JUST BROUGHT 206 1999 1.1 LX .
WHAT HAPPENS IS WHEN I START CAR IT WILL REV UP TO ABOUT 2000 RPM THEN IF I TAP THE THROTTLE IT WILL GO DOWN TO NORMAL IDLE .
BUT AFTER DRIVING FOR A WHILE WHEN I PUT CLUTCH IN CAR WILL REV UP TO ABOUT 3000. ALSO WHEN COMING TO A STOP AND PUT CLUTCH IN REVS WILL HUNT CONTINUELY UP AND DOWN BETWEEN 1000 -2000 RPM .
ITS VERY STRANGE Confused .
IVE CHANGED IDLE CONTROL VALVE, THROTTLE CONTROL, MAP SENSOR, LAMBDA SENSOR, TEMP CONTROL, I DONT THINK there's ANY LEAKS.
ANY IDEAS Crying or Very sad
woodsta
Seb
PostPosted: Mon May 16, 2011 4:15 am Up
Staff - Seb
First of all, you can remove the caps lock when you post, it's not very nice having to read through that. I've moved the thread to the right place now, unfortunately short of what you've already mentioned, I can't really suggest much else..
fredwooduk
PostPosted: Mon May 16, 2011 4:20 am Up
Ok thanks hopefully someone will have something else for me to try.
woodsta
PostPosted: Mon May 16, 2011 4:36 am Up
ECU reset.
I had exactly the same issue with a 1.1 206 a couple of weeks ago.
206info.co.uk/Forums/v.../t=95.html
Then take it for a 15 mile drive.
fredwooduk
PostPosted: Mon May 16, 2011 4:49 am Up
il give that a try thanks
woodsta
fredwooduk
PostPosted: Mon May 16, 2011 5:21 am Up
what will the 15 mile drive do ?
just wondering .
woodsta
PostPosted: Mon May 16, 2011 6:07 am Up
just wondering .
The ECU has to re-learn.
seanbmx
PostPosted: Mon May 16, 2011 7:04 am Up
i had the same problem when i broke my oil hose clip (the short hose running from cam cover to the throttle housing) my engine would rev up to about 2500 - 3000rpm everytime i diped the clutch and started the car. brought a new one from peugeot (costing £15) and now its back to normal.
so give that a try because it could be that simple.
buy it, fix it, mod it
fredwooduk
PostPosted: Mon May 16, 2011 8:27 am Up
Will it still have the same fault while driving for the 15 miles ?
woodsta
fredwooduk
PostPosted: Mon May 16, 2011 8:30 am Up
Il check that but I don't think it had any air leaks around that pipe . Did yours have an air leak from it then ? It's the breather pipe isn't it ?
woodsta
Jammo
PostPosted: Mon May 16, 2011 10:36 am Up
Im having this problem atm too! When i drive along the car will just rev itself without my foot on the pedal and when i stop it just goes crazy on the reving then nearly cuts out but just saves itself before it does? Any ideas!!
usher
PostPosted: Mon May 16, 2011 12:40 pm Up
mine did this not as bad though
was fixed by the above post with resetting the ecu
due to a flat battery
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
seanbmx
PostPosted: Mon May 16, 2011 2:08 pm Up
That's what I called it but the bloke at the parts department said it was called a oil hose
fredwooduk
PostPosted: Wed May 18, 2011 4:51 am Up
still no joy after reset of ECU . this is really starting to annoy me now lol.
also got a knock at the door from the fella next door last night telling me my hazards are going off on there own weird......
and my heating isnt working either now turn the knob and nothing happens .
this car is falling apart
woodsta
PostPosted: Wed May 18, 2011 4:58 am Up
Sounds like the battery is dying.
