Online Now [311]:
Visitors: 310
Today: 56894
Total: 105950902
Forums › The Car › 206 Problems › Explode!?!
Explode!?!
Zoe86
PostPosted: Thu May 19, 2011 10:37 am Up
Well what can i say, i took my car in for a service and the man said that the car was making a terrible noise and thought it was the cambelt. I took it for a second opinion and the mechanic said the water pump has had it and if i drive it even to the end of the road then the chances are it would explode and take the engine out with it. I am quite surprised as the car has done just over 47,000 miles.
I have asked for the cambelt and the water pump to be changed at a cost of £670. I just wondered if anyone else has had this problem?
Watch out... you have a hot hatch on your ass!
Year of 206?
What engine is it?
PostPosted: Thu May 19, 2011 10:48 am Up
does the car overheat?
cambelt+waterpump should come to around 300max imo not that much. go elsehwere.
NICKST
PostPosted: Thu May 19, 2011 10:51 am Up
There charging you about £370 to much mate
PostPosted: Thu May 19, 2011 10:54 am Up
£670 for timing belt and water pump.
Was the mechanic wearing a mask and a striped jumper?
L5_UKS
PostPosted: Thu May 19, 2011 11:04 am Up
What He Said haha
kieron
PostPosted: Thu May 19, 2011 11:08 am Up
if your handy with the spanners you could do it yourself for just over 100, you wouldnt pay 670 on a 180 and its more of a big job
Account suspended
eddrj
PostPosted: Thu May 19, 2011 11:35 am Up
as said water pump and cambelt should only be bout £300 350 max or most places less
Over £600 is a p**s take go anywhere else but there.
Would explode what the hell that man should b e on rogue traders .
Old car 2000/ 206 2.0 hdi.
Norvvv
PostPosted: Thu May 19, 2011 11:38 am Up
Dare you to drive it to the end of the road ... Very Happy
2001 1.4lx
PrePlexed 5 door.
PostPosted: Thu May 19, 2011 11:59 am Up
how much!?! they are ripping you off big time
i paid peugeot to replace my cambelt, all tensioners and idlers, water pump, auxillery belt, auxillery tensioner and coolant and it came to £430 and that was on a 180 if you have a smaller engine it should be cheaper
PostPosted: Thu May 19, 2011 12:50 pm Up
I've worked it out. It's an eco friendly garage and they are using bottled water to refill the coolant.
Werdnal
PostPosted: Thu May 19, 2011 12:59 pm Up
I had my 2.0HDI cambelt and tensioners done last year for £180. Gave water pump a miss - I know it should be done but too a chance and so far so good.
leigh_boy
PostPosted: Thu May 19, 2011 2:25 pm Up
btw for every post on this forum you ned to paypal me £300 to imarobbinbastuard @ mugmeoff.com
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Thu May 19, 2011 3:03 pm Up
If it's that likely to go pop then tow the car away.
Seb
PostPosted: Thu May 19, 2011 3:12 pm Up
Staff - Seb
This indeed, or, it cost me £50 to trailer a VX about 30 minutes. Call up your local agencies, see what they say.
