Latest: Beduff1977
Overall: 17134
Online Now [1677]:
Visitors: 1676
Today: 173756
Total: 110028215
Forums › The Car › 206 Problems › 206 GTI 180 Drop Links
nellyhaggis
PostPosted: Tue May 24, 2011 5:01 am Up
Hi,
Does anyone recommend a specific make of drop links for the 180 GTI?
Cheers.
Kev.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
PostPosted: Tue May 24, 2011 5:06 am Up
nellyhaggis wrote:
Hi,
Cheers.
Kev.
Yes, the genuine Peugeot ones you can buy at any Peugeot / Citroen main dealer Wink
DeadEyePaul
PostPosted: Tue May 24, 2011 5:07 am Up
Check out eurocarparts.com enter your reg and you get results
PostPosted: Tue May 24, 2011 5:17 am Up
Euro Car Parts drop links are fine, I can't remember the brand but they do seem to corrode a bit quicker than genuine Peugeot links.
mattymj
PostPosted: Tue May 24, 2011 5:25 am Up
I went for delphi and they have lasted much longer than the Pug ones, depends if your car is lowered or not?
PostPosted: Tue May 24, 2011 11:48 am Up
pretty sure delphi is one of the oem supplier ?
