Latest: Beduff1977
Overall: 17134
Online Now [588]:
Visitors: 587
Today: 78137
Total: 108710340
Forums › The Car › 206 Problems › 206 1.4 sport 55 plate
davidt
PostPosted: Wed May 25, 2011 1:28 am Up
Morning all
Just bought a 55 plate 1.4 206 which has developed a bit of a problem
Bought a couple of weeks ago and been in the garage since driving it up from Nottingham when it drove OK other than stalling a couple of times when setting off and if not applying plenty of revs. It was just about out of fuel and needed a jerry can top up to get it to go initially.
My daughter passed her test yesterday and took it out for the first time.
The car doesnt drive well at low revs, you have to be very gentle on the throttle to get it to pick up, once above 2000 rpm it goes fine
It is as though you are in the wrong gear, ie, setting off in second or being in third when you should be in second.
If you try to put your foot down at low revs not a lot happens, in fact it makes it worse, if you are light on the throttle it picks up and goes ok once above 2000rpm
Any thoughts?
Early days
PostPosted: Wed May 25, 2011 1:35 am Up
This sounnds similar to when a car is misfiring, it tends not to pull at low revs at all.
Does it sound like the car is misfiring??
davidt
PostPosted: Wed May 25, 2011 1:40 am Up
no, no mis fire as far as I can tell.
The best description I can think of is that its like setting off in second gear and being in third when you should be in 2nd
plugs and plug leads?
how do you get at the air filter (even that has me baffled at the minute!!)
Early days
abs06
PostPosted: Wed May 25, 2011 1:49 am Up
Air filter
Standing at front of the car
Drivers side. Thiers a gap behind the supension. That kinda goes under the windsreen. Put hand in their. And the filter is in there. Its a triangle like shape one and sits horizontal. If u have a feelnu should feel it.
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
cartoonhead
PostPosted: Wed May 25, 2011 1:56 am Up
abs06 wrote:
Air filter
thats the pollen filter , its nothing to do with the engine Shocked
the air filter is circled in RED in the picture below.
Abzynthe
PostPosted: Wed May 25, 2011 2:00 am Up
East Area Rep - Abzynthe
abs06 wrote:
Air filter
Laughing nice try though Smile
On the 1.4 sport, the filter is the long thin black box that runs along the rocker cover on the passenger side. You may have to pull out the air intake (box thing in front of the air filter) to get to all the torx screws though.
Danw_VVT
PostPosted: Wed May 25, 2011 2:16 am Up
cartoonhead wrote:
abs06 wrote:
Air filter
im sorry to say your wrong too!
on the 1.4 sport the air filter is located here :
stevesey
PostPosted: Wed May 25, 2011 2:17 am Up
Check the plug gaps - or just change the plugs (worth doing if the car is new to you anyway). At lower speeds/wide throttle opening the spark has to jump though a lot of dense air/fuel mixture which is more difficult that less dense air/fuel so wide gaps can show up then.
Could be leads/coil packs - if a lead/coil pack is breaking down the you can get arcing within the lead to complete the circuit. The air around the arc will ionise and help it to sustain the arc (so problem appears to go away as revs increase). Plugs first though.
Unlikely to be air filter - they don't get blocked as such just less efficient - and would affect the car more at higher revs as it drawns more air.
matt.handley
PostPosted: Wed May 25, 2011 2:29 am Up
mine had the same proplem when i brought it, changed the spark plaugs and the ignition coil then all was fine.
cartoonhead
awwwwww Sad
got that pic of ebay too as its advertised as a 55 plate 1.4 sport Shocked
Danw_VVT
PostPosted: Wed May 25, 2011 2:31 am Up
cartoonhead wrote:
awwwwww Sad
o dear! lol mis advertising! lol
but its as stevesey says failing that get it diagnosed as it could be the VVT getting stuck?
Abzynthe
PostPosted: Wed May 25, 2011 2:32 am Up
Danw_VVT wrote:
cartoonhead wrote:
abs06 wrote:
Air filter
Woohoo, I was right, even if the description was a bit criptic Razz
PostPosted: Wed May 25, 2011 2:35 am Up
What leads its a 206 they dont have HT leads Wink
Bosch OR genuine Peugeot / Citroen Eyquem spark plugs only! DONT fit NGK plugs to a PSA engine as they are known to cause problems / damage engine ecu's!
cartoonhead
PostPosted: Wed May 25, 2011 2:39 am Up
Danw_VVT wrote:
oH dear! lol mis advertising! lol
on ebay . NEVER Rolling On The Floor Laughing
JK
kieron
PostPosted: Wed May 25, 2011 3:18 am Up
Is this a proven fact tho? my GTI had a full service at kwik fit and ngk was fitted
i hear loads of people say ngk will damage the coil pack etc but ive seen a few 206s that have had them in for year without any problems at all
if this is the case ill get mine removed asap
Account suspended
