Forums › The Car › 206 Problems › gti180 oil pump failure |
Posted: Mon May 30, 2011 12:10 am |
pictures from our broken oem oil pump. this ended with a crappy crankshaft
do anyone know of any upgraded oil pmp?
Posted: Mon May 30, 2011 2:15 am |
I have heard that Longmans used the EW12 oil pump. Nobody seems to know why though.
