Online Now [120]:
Visitors: 119
Today: 48618
Total: 139057480
Forums › The Car › 206 Problems › clock freezing
clock freezing
dumdum0910
PostPosted: Sat Jun 04, 2011 2:15 pm Up
i have noticed every time i put the ignition on the time is always correct but then it seems to freeze . the 2 dots carry on flashing but the numbers dont change . what could be causing this?
Dabamash
PostPosted: Sat Jun 04, 2011 2:18 pm Up
Staff - Daba
Put a new headunit in recently?
try doing a soft BSI boot.
CLICK HERE
electrical and lighting section. I found mine froze after putting a new HU in, so a soft boot will probably work for you.
EDIT: Move to correct section
