Latest: Beduff1977
Overall: 17134
Online Now [591]:
Visitors: 590
Today: 158937
Total: 108791002
Forums › The Car › 206 Problems › Another non-starter =/
Rob2859
PostPosted: Tue Jun 14, 2011 5:15 am Up
I am going to cut a long story short and get to the position I am in now;
The electrics had a fit and the car was dying on the second turn of the key so I swapped the battery but now it turns and doesn't fire. Fuel is getting to the rail so its likely to be the immobiliser yes? Also the remote locking and electric windows are not working.
BSI reset failed
fuses are good
earth on the battery looks good
Still looking through the search but not finding much
Thanks in advance guys
PostPosted: Tue Jun 14, 2011 5:21 am Up
Tried the spare key?
Rob2859
PostPosted: Tue Jun 14, 2011 5:29 am Up
ops yes tried that as well.
PostPosted: Tue Jun 14, 2011 5:31 am Up
Not hit the fuel inertia switch have you? [if you have one]
Are you positive that the new battery is working?
Rob2859
PostPosted: Tue Jun 14, 2011 5:33 am Up
No I don't have one my is plexed. Seems good to be honest it turns fine. Got another one on charge however
PostPosted: Tue Jun 14, 2011 5:34 am Up
Tried bumping the car?
PostPosted: Tue Jun 14, 2011 5:38 am Up
did the plug working so as the coilpack?
Rob2859
By hand yes
Rob2859
PostPosted: Tue Jun 14, 2011 5:41 am Up
Which plug? I do have a known working coilpack, I was just thinking about going to try that.
did you play with the electric before the car die?
hope is not a fired ecu/ bsi
spark plug
Rob2859
PostPosted: Tue Jun 14, 2011 5:48 am Up
Plugs are good, just done the coilpack. It does seem like the immobiliser . Not sure about hte locking and windows though, I will check the fuses again
Rob2859
PostPosted: Tue Jun 14, 2011 6:08 am Up
When I remove fuse F4 from inside and put it back in again it bongs at me
PostPosted: Tue Jun 14, 2011 8:40 am Up
Your pulling fuses out with the battery connected? oh dear....
Fuse 4 is for the MFD, Nav ECU, Radio, Folding Roof ECU, Rear lights, Clock, Com2000, Telephone transmitter. Should be 10amp
But if your pulling fuses out while the battery was connected, you could have well corrupted the BSI
Rob2859
PostPosted: Tue Jun 14, 2011 10:07 am Up
Fixed! sort of; I turned my attention to the boot which would not unlock. I opened it from the inside and the handle is in some way fudged. Failing at fixing it I just unplugged the remote locking wire from it and it started!
However it is still running on 2 cylinders and the electric windows don't work
Lee I would appreciate it if you could look at my other thread and give me some advice as I do not think this non-start problem is related to my other problem. I will update it now.
