Latest: jtq4u
Overall: 17141
Online Now [42]:
Visitors: 42
Today: 21085
Total: 113990303
Forums › The Car › 206 Problems › Peugeot Diagnostics
Peugeot Diagnostics
Keisha206
PostPosted: Fri Jun 10, 2011 1:54 am Up
Hi,
Can anyone reccomend a reliable garage with a 206 Diagnostics kit in Teesside?
Bought my silver 54 reg independence at 49,000 miles (pretty sure it was clocked) last january from a local 'reputable' garage and its been riddled with problems. Had the coil pack replaced, new lambda sensor. Took the car to a garage reccomended to me (didnt know he was a porsche specialist before he charged me £45 an hour!!!).
He took my car to bits and discovered the air bag light and the engine management light had been covered with black mastic and duct tape. Airbag light was fixed right then but the engine management light was intermittent and went off! He ran the diagnostics tool anyway and that suggested it was the Catylic Converter...its just come back on (after a few weeks off) and ive finally got the money to get it sorted... want to double check it is the cat first (and not have to pay £45 an hour!!) any reccomendations welcome!
Cheers! Question
Miss Cox
PostPosted: Fri Jun 10, 2011 2:10 am Up
Most Peugeot garages charge £60 an hour.
Keisha206
PostPosted: Fri Jun 10, 2011 2:17 am Up
£45 an hour it is then... at least i know the guys geniune and does a good job!
Miss Cox
DanPug206
PostPosted: Fri Jun 10, 2011 2:34 am Up
Average garage charge £45 an hour labour
Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport
PostPosted: Fri Jun 10, 2011 2:38 am Up
£45 a hour labour, thats under half what a lot of garages charge so stop moaning.
leigh_boy
PostPosted: Fri Jun 10, 2011 2:44 am Up
ye pug charge £50 ish per half an hour
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Keisha206
PostPosted: Fri Jun 10, 2011 5:53 am Up
ok !! didnt know, thought this was expensive ... i was told it was!!
Miss Cox
PostPosted: Fri Jun 10, 2011 6:26 am Up
Could you not just get the codes read and see what comes up. There are quite a few code readers out there for less than you're paying per hour. Granted, they won't reset the ABS light but will do the same job as most garages.
MissGTi180
PostPosted: Fri Jun 10, 2011 6:35 am Up
Someone get out the wrong side of bed this morning
www.facebook.com/mel206
stevedude
PostPosted: Fri Jun 10, 2011 8:31 am Up
pug here charges £80ph
Happydays
stevedude
PostPosted: Fri Jun 10, 2011 8:36 am Up
look for Lee on here, he has pug planet and is up north area,
Happydays
PostPosted: Fri Jun 10, 2011 5:08 pm Up
Nope, just sick of the amount of idiots on here moaning for no good reason Wink
PostPosted: Fri Jun 10, 2011 5:34 pm Up
Not really when you consider Renault charge £127 to change a headlight bulb.
£45 an hour is cheap for a "specialist".
Contact "Lee" on here, he is a good guy with all the correct software and is a damned sight cheaper than a garage Smile
Keisha206
PostPosted: Tue Jun 14, 2011 3:00 am Up
Right there with you MissGTI!
FYI MrBSI i got it looked at at a local garage, bloke put it on the diagnostics for nothing (cause i get my MOT done there) apparently i have an ageing Catylist and a sensor on Cylinder one has gone, he's turned the engine management light off for me too.
So with the money i saved decided to start getting rid of the bumps and scratches on the car starting with the door sill where it looks like the previous owner has been digging her heels in! gotta buy some primer, got the paint match and clear lacquer - hope it works!!
Miss Cox
Seb
PostPosted: Tue Jun 14, 2011 6:38 am Up
Staff - Seb
A sensor on cylinder 1 has gone?? I have no idea what that could be as there aren't sensors on each cylinder.. other than the spark plugs and injectors?
