Latest: airmastertapes
Overall: 17133
Online Now [328]:
Visitors: 327
Today: 28367
Total: 106692558
Forums › The Car › 206 Problems › I've definatly angered the beast!
Go to page Previous  1, 2
PostPosted: Sun Jun 19, 2011 5:41 am Up
I gave my old battery to a pikey irish scrap man. His eyes lit up when he saw I had an old battery.
macj
PostPosted: Sun Jun 19, 2011 5:46 am Up
This weeks special..... all cars through workshop need a new battery or catalytic convertor...... I feel a holiday coming on
liam180
PostPosted: Mon Jun 20, 2011 10:53 am Up
well i put the new battery in, still doesnt start, this is going to sound really stupid id imagine, but do i need to get it bump started on the new one to start it charging or should it go straight away?
GTI 180 - Ring bound!
PostPosted: Mon Jun 20, 2011 10:54 am Up
Did you shut down / reboot the BSI correctly?
liam180
PostPosted: Mon Jun 20, 2011 11:00 am Up
yup as far as i know.
I'm thinking alternator?
all the electrics come on, and the car just clicks when i turn it over
macj
PostPosted: Mon Jun 20, 2011 11:08 am Up
Starter motor..... alternator wont prevent it from starting
liam180
PostPosted: Mon Jun 20, 2011 11:24 am Up
i'll get this battery a jump n see if that works....
macj
PostPosted: Mon Jun 20, 2011 11:32 am Up
Whip the starter off, and pop into an auto electrician or garage and ask them to load test it for you. Sounds to me like it has been drawing a lot of current and has killed the old battery, if there is a short in it now it would explain the clicking.... solonoid working but motor not turning
liam180
PostPosted: Mon Jun 20, 2011 11:41 am Up
Unfortunatly giving me more credit than i deserve, I can't even see the starter let alone take it off mate
macj
PostPosted: Mon Jun 20, 2011 11:44 am Up
point taken...... dont spend any more money till you get it tested though
PostPosted: Mon Jun 20, 2011 11:53 am Up
Follow the thick + cable towards the engine block, the starter motor will be connected to it somewhere along its length.
The alternator should be at the other end of the cable.
The starter motor turns the flywheel, its not gonna be that hard to spot / find.
Page 2 of 2
