Posted: Tue Jun 21, 2011 3:17 pm |
Hi guys and gals, (new to site) had my 206 3 years not an ounce of trouble, until of late when my o/s tail and side lights decided to play silly buggers and not come on, fuse bulbs i thought? no luck there apparantly doesnt work of a fuse bulbs ok . i am now at a stage where my n/s tail-side lights stay on after turning off the ignition and o/s still not working tried rebooting b.s.i. anybody got any solutions
| | ![](images/spacer.gif) |
| 206 2ltr Hdi glx 53 plate | |
Posted: Tue Jun 21, 2011 3:24 pm |
You checked if there is power going to the lights?
Any electrical mods?
Posted: Tue Jun 21, 2011 5:17 pm |
No modifications at all to the electrics. when i first had problems with the o/s tail/side lights I did take the car to a garage i have used before (decent guy) He got the lights back on by running some sort of tester and lead from front to back. a week later a family friend did a diagnostic test on the car for my own curiousity more than anything, to see if there were any other probiems. bad mistake on my part. the light fault came back and got worse hence both sides what do you sugest lee
Posted: Wed Jun 22, 2011 7:53 am |
Do you have a multimeter to test the wiring?
So does all the lights work except the sidelights?
Wiring diagram attached
Posted: Wed Jun 22, 2011 7:56 am |
Lee wrote: |
![Wink Wink](images/smiles/icon_wink.gif)
Posted: Wed Jun 22, 2011 11:40 am |
Afraid not (no multimeter) forgot to mention earlier number plate lights out as well. all other lights on the car are A1 OK. Have a HAYNES MANUAL and already checked their wiring diagrams.. will look at yours as well much appreciated. would your diagnostics equipment be my next port of call or would a test with a multimeter be appropiate first.
Posted: Wed Jun 22, 2011 12:26 pm |
You could test it via a multimeter if you have one.
Does the side lights on the front work?
I could come and try and diagnose it, and if it is a wiring fault, potentially rewire it for you.
Posted: Wed Jun 22, 2011 2:22 pm |
Hi LEE
Don't have a multimeter, n/s side light/tail light working but not turning off, (on constantly ) bypassing stalk switch, also when key out of ignition.
o/s side light /tail/number plate lights not working at all.
It'll be great if you could solve the problem for me. where is sheffield 25 (what area of sheffield is that.) only been a lgv driver for 35 years '
could meet you half way, or something. when are you available, MOT run out last week oooooops
my mobile number is 07954413790
Posted: Wed Jun 22, 2011 2:24 pm |
Does the front side lights work?? If they do, you could just rewire the rear lights by piggy backing the front.
Posted: Wed Jun 22, 2011 5:29 pm |
with the stalk light switgh in the off position n/s tail and side light stoppivg on
with the stalk light switch in the 1st position (side lights tail lights) n/s lights on o/s lights not coming on
no problems with headlights 2nd position
hope this has been explained more clearly
Posted: Thu Jun 23, 2011 2:17 am |
i think he means the lights on the outer edge on the front lights, not the headlights. When you put the side lights on, you should get a little light in each front light coming on.
Posted: Thu Jun 23, 2011 6:12 am |
Sorry to confuse? in my third statement. afraid not (no multimeter} was just stating i dont have a multimeter.
headlights working fine.
Posted: Thu Jun 23, 2011 11:00 am |
Front sidelights not headlights
![](http://carphotos.cardomain.com/ride_images/2/4457/4621/23642310003_large.jpg)
Need to find out if the whole side light circuit is faulty or just the rear
Posted: Thu Jun 23, 2011 11:48 am |
Thanks for that LEE.
Not my thing electrics, only know the basics fuses, bad earths etc
I will go and get car tested with a multmeter and let you know
You know when you do a reboot of the bsi, and you let the bsi go into safe mode
is it the the same safe mode that comes on that protects the battery from going flat
And when it says to turn off all apliances. with the problem i've got lights on all the time do i take the bulbs out when doing reboot
Posted: Thu Jun 23, 2011 11:51 am |
Just turn the sidelights on and have a look at the front of the car ![Laughing Laughing](images/smiles/icon_lol.gif)
