Latest: Beduff1977
Overall: 17134
Online Now [2064]:
Visitors: 2063
Today: 42401
Total: 107702656
Forums › The Car › 206 Talk › Average life expectancy of a 206?
copey
PostPosted: Tue Jun 21, 2011 2:14 am Up
the key is regular servicing and they seem togo forever
02 2.0 hdi d turbo
PostPosted: Tue Jun 21, 2011 2:23 am Up
I've had 6 206s.
2002 1.1 - Had it until 70k miles. Only needed a clutch change in the time I had it.
2002 GTi 138 - Had from 60k miles to 100k miles. A number of issues, but none with the engine (apart from the rebuild, but that wasn't due to wear & tear)
1999 GTi - 120,000 miles, no service history. Failed MOT for a shot rear axle. Suspension had all sorts of problems so I broke the car.
1999 GTi - 92,000 miles. Head gasket failure.
2001 GTi - 90,000 miles. ICV problem, but ran great.
1998 1.1 - 128,000 miles. ICV problem. No other issues.
Twidly
PostPosted: Tue Jun 21, 2011 2:33 am Up
My friend's 306 diesel has last up to 190K, now it's dead, But I think it's just something simple like a alternator or something, so it would probably last longer if he bothered to fix it... I'm hoping mine will last up to 140K. That'll do me.
spud_owen
PostPosted: Tue Jun 21, 2011 3:10 am Up
as someone has siad before it depends on how well looked after it is and how willing you are to shell out for new /second hand bits to keep it going, i think the engine block and head will last forever on my car, still pulling as strong as anything but its all the bits around it which need changing, i do drive it quite hard though and do a min of 20k a year
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
Dan206
PostPosted: Wed Jun 22, 2011 6:30 am Up
My 1.4 hdi is on 165000ish at the moment, ive owned it a year and since then its had a new starter motor, crank pulley some new belts and just some general engine maintainence. Its been serviced a couple of times and has been well looked after. If your willing to spend money on them they will last.
Lewis1592
PostPosted: Wed Jun 22, 2011 5:45 pm Up
sittin at 108k. engine as good as ever. plan on running it to at least 150k before changing car.
2001, 206 1.4 lx first car Very Happy
leffex
PostPosted: Tue Aug 16, 2011 12:47 pm Up
sitting with a 184,000 miles engine still going strong! Dun forget to change the oil(THE-SECRET-IS). Y know Taxis are driving quite alot and their cars are highmilage but they still go on and on.
Sweden guy loves his 180k miles Orange XS
ExoVyper
PostPosted: Tue Aug 16, 2011 12:58 pm Up
69,000 for a 2L HDi.....
well for all i know it could've started back up if i repaired the fuel lines after impaling it into a brick wall lol
PostPosted: Tue Aug 16, 2011 1:23 pm Up
Theoretically the GTi could last longer than any of the other engines. Its size means it is less stressed than smaller engines and it's no more complicated that any other 16V engine. There's no turbo to break either.
They tend to get serviced more often too but then they also get driven harder.
PostPosted: Tue Aug 16, 2011 1:30 pm Up
Ste206 wrote:
Andrewxps wrote:
Thanks everyone, it put my mind at rest. I shall let the car warm up for a few minutes before going on my short journeys from now on Smile
As for diesels, can the 1.9 live as long as the 2.0 hdi?
You hear about volvos that have a million miles on the clock, is the 2.0 hdi a contender? My grandad has one and says it should outlive the bodywork
Are 138s/180 doomed to a short life? As I have heard they are delicate
I'm not sure it's that there delicate, more that most of them live an abused life lol.
fast versions of hot hatch backs tend to unfortunately mostly be owned by the trun the key and rag the hell out of it brigade but if looked after should last just as long as other versions
i always allow mine to get up to normal oil and coolant temps until i rev it over 3000k and always drive easy for the last couple of miles before i switch it off i check the levels weekly and service it with genuine only parts and iv just hit 64k with no faults at all so far (iv had it since it had done 14K)
Andrew
PostPosted: Wed Aug 17, 2011 3:23 pm Up
Nice to see there are still replies coming in here, I really like my car and plan to keep it a long time so I wanted to know what to expect Smile
My 206 thread
www.detailedbyandrew.com
ab16
PostPosted: Sat Aug 20, 2011 6:53 pm Up
Really depends on driving style and roads you be driving on. If the roads are bumpy and your going fast then the car will need more repairs etc.
wanted-
ph2 bootstrip
16'' nimrods
sports front and rear bumpers
ph2 rear lights
PM with any good deals Wink
PostPosted: Sun Aug 21, 2011 7:14 am Up
Give it about 6 weeks & there will start to be plenty of dead 206's showing up on here Laughing
Its getting near the time of the year where certain types of people start running out of driving talent, happens every year on here without fail Rock Onnnnn..
namgaj
PostPosted: Sun Aug 21, 2011 8:04 am Up
Very true!!!
4.0 V8 S-Type Jaguar
bashyy1
PostPosted: Sun Aug 21, 2011 8:05 am Up
Best post, I'd like to agree with this.
Aegean Blue Gti 180.
Project Thread
Page 3 of 4
