Latest: tc.206
Overall: 17147
Online Now [67]:
Visitors: 66
Today: 19009
Total: 116364504
Forums › The Car › 206 Talk › Roof strips removal question
davieboy86
PostPosted: Thu Jul 07, 2011 2:48 pm Up
I was going to paint those plastic strips that you can take off of the roof (go all the way to the bottom of the windscreen) but i was wondering will the car still be water tight over night, ( I am not stupid enough to think that it goes straight through to the interior of the car, but surely they have a purspose?)
i havent pulled them off yet so im not sure whats underneath or how tbh so any guidance is appreciated.
Thanks guys
Andy180+
PostPosted: Thu Jul 07, 2011 2:49 pm Up
it will be ok
just pull them off stright up
Abzynthe
PostPosted: Thu Jul 07, 2011 2:51 pm Up
East Area Rep - Abzynthe
You might need some pliers for the clips at the bottom of the windscreen though. Ive had to put screws in mine to hold em down after I wrapped them. But will be water tight Smile
Andrew
PostPosted: Thu Jul 07, 2011 2:54 pm Up
I'm interested in this as well, would like to do mine gloss black. Is it a torx screw at the botton and then just pull up?
My 206 thread
www.detailedbyandrew.com
Abzynthe
PostPosted: Thu Jul 07, 2011 2:55 pm Up
No its a plastic clip. just pull em with pliers, your most likely going to brake them because they are brittle, but a small screw works a treat Smile
Rob2859
PostPosted: Thu Jul 07, 2011 2:56 pm Up
They have some funny plastic clips on the bottom. Could't work out how to remove them so I just ragged them off. They are still perfectly secure
davieboy86
PostPosted: Thu Jul 07, 2011 2:57 pm Up
what sort of clips, standard trim clips or metal clips like on the foglight connectors or actually moulded plastic on the stripp itself?
Abzynthe
PostPosted: Thu Jul 07, 2011 3:03 pm Up
its hard to explain, they are flat and round on the top and they push into a hole in the strip then into the metal underneath.
