Latest: S2cgm
Overall: 17178
Online Now [190]:
Visitors: 188
Bots: 2
Today: 37745
Total: 137307309
Forums › The Car › 206 Problems › Possible flat battery and BSI frying !!
gixxerkev
PostPosted: Fri Jul 08, 2011 4:54 am Up
Hi everyone, Im away fighting the war on terrorism at the moment and when I return to good 'ol Blighty in a couple of weeks Im expecting my battery to be flat. After reading so much about "frying" BSI's etc, Im wondering if its possible to "jump start" my 2003 1.4 GLX just like you would any other car, or is there a risk of doing some damage to the BSI ?. Any advice would be most welcome as the last thing I want is a knackered car and a desperate girlfriend in the middle of the night, if you catch my drift !! Wink
Thanks in anticipation
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Fri Jul 08, 2011 5:15 am Up
Shouldnt have left the battery connected if the car is left standing.
War on terrorism or the war on Islam and oil?
Try to bump start it rather than use jump leads. If you need to use jump leads then turn the side lights on to try and absorb any spiking.
copey
PostPosted: Fri Jul 08, 2011 5:17 am Up
can you not just get a battery charger from somewhere
02 2.0 hdi d turbo
PostPosted: Fri Jul 08, 2011 5:27 am Up
do u still need to do that when you use a power pack?
gixxerkev
PostPosted: Fri Jul 08, 2011 5:39 am Up
Now there's a thing MrBSI, Ive read so much about disconnecting the battery as well, open drivers window, disconnect battery, stand on 1 leg for 3 mins, re-connect, turn ignition on etc etc, why cant pugs just be like any other bloody car? If Id done as Ive read about diconnecting the battery the drivers window would of been open for 2 months.
As for the battery charger Copey, not a chance, its parked in the middle of a massive car park at least 250 metres away from the nearest building on a military base !!!
Thanks Lee for some constructive advice.
Morrj
PostPosted: Fri Jul 08, 2011 5:48 am Up
soft booting the bsi is just a precaution not a necessity, at the end of the day its worth takin a few extra minutes when doin things so you don't cause any unnecessary problems for yourself.
PostPosted: Fri Jul 08, 2011 6:03 am Up
Its due to the sensitivity of the BSI. Its because as soon as you unlock the car it wakes up. It's like you on your PC and someone rips the plug out of the socket, you're defiantly going to lose some things and it might corrupt the PC
When you attempt start it, turn all unnecessary electrics off, then turn it to the ignition and back off a couple of times to let the fuel pump, pump some fuel around the engine, sometimes eases starting.
You should really Seabook, just helps prevent spiking
PostPosted: Fri Jul 08, 2011 6:19 am Up
With the utmost, greatest, sincere respect... It does not.
(And I know full-well who I'm talking to). Wink
PostPosted: Fri Jul 08, 2011 6:32 am Up
It can do. Well according to the VAG group. Only going on what I read in their self-study program Laughing
I'm no electrician btw, just saying what I read in there Laughing
PostPosted: Fri Jul 08, 2011 6:39 am Up
If it was that simple, they would include a suitable resistor in the BSi/ECU itself, which is then taken out of circuit after power-up from cold.
We could go into this to some depth, but the sort of near-instantaneous
spike caused at so many KV is impossible to catch (arrest) even with a lot
of active components etc. let alone a couple of resistors (lamps).
Wink
PostPosted: Fri Jul 08, 2011 6:46 am Up
Like I said, I'm no electrician or mechanic, never studied it in my life. Just know what I've taught myself thru reading and trial & error Smile
Speaking of which I need to get a 22k resistor and a 1n4007 diode for a bmw seat
Ape
PostPosted: Fri Jul 08, 2011 6:49 am Up
I used to jump start mine regularly (I was always taking it apart and rebuilding it so it spent alot of time with a flat battery) and never had any problems.
