Latest: Beduff1977
Overall: 17134
Online Now [2431]:
Visitors: 2430
Today: 42535
Total: 109897422
Forums › The Car › 206 Problems › Bonnet alignment
Bonnet alignment
Andrew
PostPosted: Wed Jul 13, 2011 2:06 pm Up
Hi
I've noticed that the gap between my bonnet and drivers wing is slightly bigger than the gap on the other side
Its not a big issue but it annoys me. Is there anyway I can tweek the alignment easily to match?
The wings are aligned fine in themelves
Cheers
My 206 thread
www.detailedbyandrew.com
Uz
PostPosted: Wed Jul 13, 2011 2:12 pm Up
Adjust the hinges themselves. Just loosen the bolts and twist the bonnet as you need to and just tighten back up.
imjeeves
PostPosted: Wed Jul 13, 2011 2:13 pm Up
Yes loosen the bolts where the bonnet attach to the shell then move to the required position and tighten again.
They are 10mm I think from memory
Andrew
PostPosted: Wed Jul 13, 2011 2:17 pm Up
Thanks guys, I spotted the hinges had small bolts but I didn't know it was just a job of loosening them and repositioning it.. I was expecting to be told I'd have to take it off and put it back on haha
My 206 thread
PostPosted: Wed Jul 13, 2011 3:02 pm Up
as said but is quite fiddly job will take you a long time to get it perfect normally ends up worse first few times lol
Andrew
PostPosted: Wed Jul 13, 2011 3:24 pm Up
Its not diagonal or anything, just needs bringing to the left a mm or 2, so I will loosen the bolts, shift it accordingly and retighten
Is there a specific torque for the bolts to be tightened again?
My 206 thread
imjeeves
PostPosted: Wed Jul 13, 2011 4:12 pm Up
Probably but just do it till they feel tight
