Latest: tbafonso
Overall: 17130
Online Now [231]:
Visitors: 230
Today: 21763
Total: 103208347
Forums › The Car › 206 Problems › Peugeot 206 1.6 Convertible 2004
ChristAlmighty
PostPosted: Wed Jul 20, 2011 1:48 am Up
How easy is it to replace the entire aerial unit on the front of the roof?? mine has broken off past the screw in part
Hi
PostPosted: Wed Jul 20, 2011 2:10 am Up
Pull back the headlining and its a couple of 10mm nuts if I remember right.
ChristAlmighty
PostPosted: Wed Jul 20, 2011 3:42 am Up
thanks alot Very Happy saves expensive main dealer rip off lol
Hi
craigdmjv
PostPosted: Wed Jul 20, 2011 6:17 am Up
im a cc owner but have no idea i this is behind the map light and undo a bolt
PostPosted: Wed Jul 20, 2011 12:18 pm Up
Other garages are more than capable of fitting a new aerial!
