Latest: Beduff1977
Overall: 17134
Online Now [1023]:
Visitors: 1022
Today: 45918
Total: 107706172
Forums › The Car › 206 Problems › Window WIPER HELP!
Window WIPER HELP!
deebee
PostPosted: Sun Jun 19, 2011 6:48 am Up
guys, i drove the other day to this shop got back out and wipers where up not like sideways, i turned them off, then i relised there where sitting abit further up than normal so i pressed the button agen and nothing happened, checked all fuses, when i took Main fuse out it swiped across so i tried it again and it failed to do so. Any options?
Breaking 2.0 hdi with ps and gti bits
PostPosted: Sun Jun 19, 2011 7:26 am Up
You knocked the wiper stalk when you got out & that put the wipers in to service position Wink
Normaly you just operate the stalk for flick wipe again to get the wipers back to the normal park position.
Also to be fair this information isnt in the owners handbook.
deebee
PostPosted: Sun Jun 19, 2011 10:52 am Up
sorry i dont understand how you mean?
PostPosted: Sun Jun 19, 2011 10:56 am Up
The wipers where bolt upright on the screen = there in service mode
Rob2859
PostPosted: Thu Jul 21, 2011 4:37 am Up
Just found this with the search (go me). Its what I encountered last night however the wipers do not operate at all now and the fuse is fine.
Rob2859
PostPosted: Thu Jul 21, 2011 9:29 am Up
Also if I remove the fuse for the BSI the wipers work by themselves on intermittent so its not the motor.
Rincewind
PostPosted: Thu Jul 21, 2011 9:38 am Up
Might be an idea to check all the earth points on that circuit and also if you have a spare relay try swapping them. Smile
206 XSI 1.6
Rob2859
PostPosted: Thu Jul 21, 2011 9:40 am Up
Do you know where the relay is? I should be able to find the earthing points.
deebee
PostPosted: Tue Aug 02, 2011 7:12 am Up
I checked up on old posts and relised i forgot to tell you, i simply played around with the stalk... and then thought why not il check every option i can, i checked the level off washer fluid in the bottle and it looked quite low, i simply apllied water ah wahey, they up and running again! how stupid image your in the p**sing rain and u go to wipe your windows but cant because there's no washer fluid in there AHAHA pointless creation
Rob2859
PostPosted: Tue Aug 02, 2011 9:11 am Up
They are working now. I replaced the bsi while trying to fix something else and they worked. Thanks for your help anyway. My wipers have always worked when there has been no screen-wash in :s
