Latest: Beduff1977
Overall: 17134
Online Now [582]:
Visitors: 581
Today: 34742
Total: 107970073
Forums › The Car › 206 Problems › Torsion bar lowered wrong
Rob2859
PostPosted: Thu Jul 21, 2011 9:48 am Up
I was going to lower the bar myself but seen as I didn't have a spring compressor it needed to be done at a garage anyway. So I thought I would save myself the effort of unseizing the torsion bar myself and let a garage do it.
I found out after that they had done it via the spline method. How likely is it to cause problems?
I have read the how-to on lowering the other way but do not know how to adjust it with this method.
PostPosted: Thu Jul 21, 2011 10:01 am Up
Try it the way my mate says to. Throw a few bags of cement in the boot to drop it to required height & then heat the bars/arms up with a blowtorch and then just throw a bucket of cold water over it Wink
brimbo
PostPosted: Thu Jul 21, 2011 10:06 am Up
The poor man's lowering guide Very Happy but clever non the less !
W-reg 1.4 LX
Ape
PostPosted: Thu Jul 21, 2011 10:08 am Up
Confused
PostPosted: Thu Jul 21, 2011 10:12 am Up
Haha, Brainiac, The lazy mans guide Wink
PostPosted: Thu Jul 21, 2011 10:37 am Up
if you are worried you can always replace the bearing.
PostPosted: Thu Jul 21, 2011 10:43 am Up
Bucket of water and then you've got to kneel or lie in the puddle...Nice.
imjeeves
PostPosted: Thu Jul 21, 2011 11:15 am Up
What do you mean by spline method.
Remove bars and rotate round 1 or two?
If they are done with a dummy shocker then it is the correct way to do it.
Otherwise take it back because you have been ripped off
Callum206
PostPosted: Thu Jul 21, 2011 12:34 pm Up
Laughing F**K that.
Rob2859
PostPosted: Sat Jul 23, 2011 5:39 pm Up
oh dear. I think it will be fine. Nobody has actually said why it is wrong anyway Very Happy
