Latest: eltel666
Overall: 17146
Online Now [124]:
Visitors: 123
Today: 15312
Total: 116206894
Forums › The Car › 206 Problems › Bad MPG 1.9D
Bad MPG 1.9D
joshack
PostPosted: Mon Jul 25, 2011 12:58 pm Up
My 1.9d seems to be getting about 25-30 mpg and im getting about 400 miles to a tank which doesnt seem right. To say the tank is about 50 litres.
Any ideas why?
drive:206 lx diesel
PostPosted: Mon Jul 25, 2011 1:00 pm Up
Ever been properly serviced?
joshack
PostPosted: Mon Jul 25, 2011 1:03 pm Up
I service it every 3000 miles, air filter, oil, oil filter, fuel filter, drained water out of fuel, cleaned inlet up best i could, blanked EGR off as was broken.
drive:206 lx diesel
PostPosted: Mon Jul 25, 2011 1:04 pm Up
Blocking the EGR will do the MPG
Is the 400miles to a fuel light or empty?
joshack
PostPosted: Mon Jul 25, 2011 1:19 pm Up
Empty, the inlet was covered in thick clumpy oil stuck to it so i cleaned the inside out but couldnt get to the metal inlet at the back of the block.
drive:206 lx diesel
PostPosted: Mon Jul 25, 2011 2:07 pm Up
How fast do you drive?
joshack
PostPosted: Mon Jul 25, 2011 3:31 pm Up
Just steady away really, keep it at low rev range, trying to be in as high a gear as possible without juddering.
drive:206 lx diesel
PostPosted: Mon Jul 25, 2011 4:26 pm Up
Did the exhaust blowed? Any misfire? Stable idle?
PostPosted: Mon Jul 25, 2011 4:29 pm Up
Have you actually worked the MPG out, or is this just a total guess?
Seb
PostPosted: Mon Jul 25, 2011 4:40 pm Up
Staff - Seb
Well my GTi does about 360 to the fuel light and I thought that worked out as about 32ish mpg last time I checked.
joshack
PostPosted: Mon Jul 25, 2011 5:09 pm Up
Did it on one of those online calculators, brimmed at my Gdads then drove it around when used a bar filled up again then worked out how much diesel it took to fill up again and the amount of miles and it brought up 27mpg
drive:206 lx diesel
joshack
PostPosted: Mon Jul 25, 2011 5:10 pm Up
Oh and it seems to have a small misfire in 1st and 2nd then disappears but its only a small flatspot really, no exhaust blows and yeah it has a stable idle
drive:206 lx diesel
xspongerx
PostPosted: Tue Jul 26, 2011 1:49 am Up
Mine does 400 to a tank...
Kersh
PostPosted: Tue Jul 26, 2011 2:03 am Up
red diesel?
Member number: 36
PostPosted: Tue Jul 26, 2011 2:14 am Up
Kersh wrote:
red diesel?
Plus concentrated hydrochloric acid (try to get over 0.5%) or filtering thru kitty litter sometimes works
