Latest: Puggingalong
Overall: 17129
Online Now [245]:
Visitors: 244
Today: 23382
Total: 101230566
Forums › The Car › 206 Problems › Rear axel bush
Rear axel bush
kieron
PostPosted: Mon Aug 01, 2011 3:12 pm Up
Im after some advice on changing a rear axel bush on my GTI as is got alot of play in it
what i want to know is can you do it with the axel still on the body, i know the 2 TB,S and ARB shock had to be taken off and then the bearing/bush has to be pressed in. i can get it pressed in by a mate who has a 10 ton press
also is this what i need? BUSH KIT
Would it be any cheaper on main dealer trade?
cheers kieron
Account suspended
imjeeves
PostPosted: Mon Aug 01, 2011 4:31 pm Up
Wont be able to do that on the car mate. Need removed and pressed in correctly into the axle tube
PostPosted: Mon Aug 01, 2011 5:01 pm Up
it would be cheaper to get it from dealer (trade price).
i think you press the bearing into the arm but not the tube?
kieron
PostPosted: Tue Aug 02, 2011 1:43 am Up
Ive seen a thread on here about it and they are pressed into the arm, but didnt know if you could just take the bars out, then bash the arm of from behind to get it off
Account suspended
PostPosted: Tue Aug 02, 2011 4:19 am Up
that's what i did
AX-Rated
PostPosted: Tue Aug 02, 2011 4:44 pm Up
I did a tasty 'How To' about fitting these, thread named 'How to change Rear Radius Arm Bearings' or something along those lines...
Black 03 GTi
