Latest: S2cgm
Overall: 17178
Online Now [273]:
Visitors: 272
Today: 57289
Total: 137326732
Forums › The Car › 206 Problems › tap tap tap tap tap tap tap (say very quickly)
Davels
PostPosted: Wed Jun 01, 2011 4:57 am Up
Ok, so my car is making the above noise when accelerating between maybe 2000 and 3500 RPM.
It's not tapping at Idle and the tappets are only a few hundred miles old so it's not them.
I've read about the common manifold rattle and armed with the print out of the 4 pipes I shoot off to the local exhaust place.
I say I have a rattle, it's either this (shows paper with manifold pipes) or the olive clamp that holds the midsection to the manifold.
They check the car over no rattles from the manifold at all but the back box is ruined. I kind of knew this was dying and after hearing them bang the back box and hearing the baffles rattle like a good'un I decide ok sod it I need a new one. Will this take care of the noise?
I'm assured yes it will.
So I get it fitted and I now have a pretty much brand new entire system. (mid section and cat replaced a month or so ago)
I pick the car up as they are closing and as I drive away the noise is still bloody there.
So one of two things has happened;
When I asked them to rev test it they didn't rev high enough to get the rattle/tap going and when the inspected the manifold itself they missed any movement that may have been there.
Or two it's it not the mani and it's something else, but what???!!!
The noise sounds like it's coming from the centre console, engine side of the firewall but slightly under the car.
Yes I know it sound suspiciously like the location of the manifold but what else "could" it be?
PostPosted: Wed Jun 01, 2011 5:01 am Up
Probably a loose heat shield.
furryhobnob
PostPosted: Wed Jun 01, 2011 5:29 am Up
I had the same issue and it was the baffles inside the middle silencer, it was only 2 months old aswell, replaced it with a custom stainless from cat back and no more rattles since
Davels
PostPosted: Wed Jun 01, 2011 9:02 am Up
I've had all the heat sheilds checked and welded before and there are none near the area the noise is coming from that I can see.
And the noise was there before the new midsection, just got worse recently. Probably becuase the rest of the car is now silent (or as close to as a french car can be) after all the work done.
craigdmjv
PostPosted: Fri Jun 03, 2011 3:13 am Up
i have a very quite rattle too but dont know if thats just the gearbox, poor thing fixed in two weeks from today 750 inc VAT cant wait now!!!!!!
seanbmx
PostPosted: Sun Jun 19, 2011 10:01 am Up
sounds like incorrect valve clearance to me, if the gap between the rockers and the valves is too big that would make the tapping noise you are hearing
buy it, fix it, mod it
yanto
PostPosted: Mon Jun 20, 2011 11:01 am Up
just fixed mine, mine is a 20l hdi ,it was the injector
got 1 from the scrapyard , got four for £50,
twenty minute fix
YANTO
Davels
PostPosted: Tue Jun 21, 2011 9:27 am Up
Hydraulic tappets are auto adjusting and would have been my first bet if they haddn't already been replaced and the noise was present at idle and when being reved. But it's only when under load between 2200-3000rpm
ryanbfox
PostPosted: Sun Jul 31, 2011 5:17 pm Up
i got the same problem with my car, it sounds like a hollow ticking noise from the engine bay, the funny thing is it only happens when i accelerate, in idle its quiet and when i de-accelerate you cant here it??? it f**king annoying, when i hit the motor way it goes away after 3500 rpm and when im just cruising along its fine but the noise is starting to get worse
Ryan
ryanbfox
PostPosted: Mon Aug 01, 2011 2:10 pm Up
got told its the exhaust manifold today if not then its the coil pack
Ryan
Davels
PostPosted: Tue Aug 02, 2011 3:10 am Up
Yeah it'll probably be the mani like mine probably is. I just havent found anyone willing to weld it for me.
ryanbfox
PostPosted: Tue Aug 02, 2011 2:38 pm Up
got quoted 400 quid to do the mani and then someone confused the whole situation and told me it could be the coil pack??? huh??? im so confused, someone please help.
Ryan
Davels
PostPosted: Wed Aug 03, 2011 7:56 am Up
£400 to weld the 4 internal pipes at the bottom of the manifold? Thats more than what I would call step! Are they gold plating the welds?
If the coil pack is fuzzing up, I would have thought it would have other systoms or make the noise throughout the revs?
Mines not the coil pack as I had the noise before and after getting a new one
PostPosted: Wed Aug 03, 2011 8:04 am Up
Have you checked the manifold gasket? That is what my annoying tapping sound has turned out to be, and I had the same symptoms you have. Smile
ryanbfox
PostPosted: Wed Aug 03, 2011 1:34 pm Up
No 400 quid to replace the manifold
Ryan
