Latest: sparrowdclxvi
Overall: 17139
Online Now [75]:
Visitors: 74
Today: 15998
Total: 112670956
Forums › The Car › 206 Talk › cambelt ecu
cambelt ecu
sx206
PostPosted: Sat Aug 06, 2011 4:28 am Up
doing cambelt kit on 1.4lx petrol,looking at haynes it says to remove ecu.will it cause a problem if left in place.any help appreciated thanks.
206
PostPosted: Sat Aug 06, 2011 4:32 am Up
Chances are with the ECU in place you might not have enough space to access the cambelt.
dumdum0910
PostPosted: Sat Aug 06, 2011 5:32 am Up
i never removed the ecu when i done the cambelt on my 1.1 . once you remove the cambelt caseing. you have enough room
PostPosted: Sat Aug 06, 2011 5:55 am Up
Tbh on a 1.4 you might not have to move it but if you find you need just move it out the way a little it's no big deal
PostPosted: Sat Aug 06, 2011 7:01 am Up
sx206 wrote:
looking at haynes
Throw the Haynes book of mystery in the bin, these newer Haynes books are total rubbish.
sx206
PostPosted: Sat Aug 06, 2011 7:14 am Up
thanks for info guys, ecu will stay put.not a big deal to move it but tamper proof fixings on mine were a pita,especially if there's no good reason to move it.hanyes book of bs for sure. Smile
206
