Latest: Beduff1977
Overall: 17134
Online Now [143]:
Visitors: 142
Today: 1810
Total: 107107368
Forums › The Car › 206 Problems › Socket won't go onto spark plug!
jonny_fulton03
PostPosted: Tue Aug 09, 2011 10:04 am Up
Hey,
Im trying to change my spark plugs but the one on the far right (cylinder 1?) is being exceptionally stubborn! I can't get the socket to sit on the spark plug so i can twist it out! All the others are fine but this one just won't go on. Ive tried pushing a bit harder down onto the plug with the socket but to no avail. Any ideas? Car is a 1.4 1999 206.
Cheers. Joni
MrrNoName
PostPosted: Tue Aug 09, 2011 11:05 am Up
slightly larger socket? be careful not to cross thread as thats a real nightmare
PostPosted: Tue Aug 09, 2011 11:16 am Up
Make sure there no rubber plug or anything on top of spark plug,
Iirc 16mm deep is the correct size??? Someone will correct if wrong.
00budham00
PostPosted: Tue Aug 09, 2011 11:47 am Up
What He Said
PostPosted: Tue Aug 09, 2011 1:24 pm Up
You need spark plug sockets usually, there longer than normal sockets.
dafdavies
PostPosted: Wed Aug 10, 2011 6:34 am Up
yea its a 16mm spark plug socket i done my car this mornig
Team: If you cant find the tool you need make one
jonny_fulton03
PostPosted: Thu Aug 11, 2011 6:21 am Up
If I had the wrong size socket would it not fit on the other plugs though? It fits on all the rest! Just not that one! Joni
PostPosted: Thu Aug 11, 2011 8:21 am Up
You need to use the correct sized spark plug socket.
