Latest: S2cgm
Overall: 17178
Online Now [133]:
Visitors: 133
Today: 54366
Total: 137204087
Forums › The Car › 206 Problems › Will a 2001 406 2L manifold fit an 2002 206 GTI???? SOLVED
paulyd101
PostPosted: Fri Aug 12, 2011 11:37 am Up
Any knowledge would be much appreciated.
Cheers
Paul
Paul 2002 206 GTi Moonstone Blue
furryhobnob
PostPosted: Fri Aug 12, 2011 11:39 am Up
I don't think it will pal, I'm sure someone will be able to enlighten you properly ad to whether it will fit or not
macj
PostPosted: Fri Aug 12, 2011 12:54 pm Up
Engine code??
PostPosted: Fri Aug 12, 2011 12:56 pm Up
Question is why?
Not the normal 206 GTI manifold rattle problem is it?
paulyd101
PostPosted: Fri Aug 12, 2011 1:25 pm Up
Yes it's the usual problem of the rattle. It looks identical from the top end. My pal has one down his breakers yard.
paulyd101
PostPosted: Fri Aug 12, 2011 1:27 pm Up
Might be a dum question but how do I obtain my engine code.
Andy180+
PostPosted: Fri Aug 12, 2011 1:42 pm Up
take it off and get the four branches inside welded together, did this 4 years ago on wifes 2l cc and not a rattle since Wink
PostPosted: Fri Aug 12, 2011 1:43 pm Up
nopt it won't, it's far too long
paulyd101
PostPosted: Fri Aug 12, 2011 2:14 pm Up
Cheers mate is that for definate as I will have to get my manifold tack welded to stop the pipes rattling.
Cheers
Paul
PostPosted: Sat Aug 13, 2011 5:31 am Up
Cheers
Paul
That is the offical Peugeot fix while the car was still under manufacturers warranty Wink
Tack weld the 4 pipes together & also tack them to the outer pipe as well.
paulyd101
PostPosted: Sat Aug 13, 2011 7:27 am Up
Ok Folks thanks very much for all your attention.
