Online Now [90]:
Visitors: 90
Today: 20304
Total: 139029264
Forums › The Car › 206 Problems › puddle of water under back seat
tamz
PostPosted: Wed Aug 17, 2011 4:12 am Up
hi can anyone help , i have a 3 door 206 and have been finding water under my rear seats , does anyone have a clue on ware this can be coming from !!!!!!!!
gpvecchi
PostPosted: Wed Aug 17, 2011 4:16 am Up
I think water comes from black caps you can find under your seats. I had 2 206 and both of them had the same problem. I never looked for a solution...
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
Check the window seals
sillyhilly
PostPosted: Wed Aug 17, 2011 5:09 am Up
Search the damn website!
Hi Mikey Smile
PostPosted: Wed Aug 17, 2011 5:15 am Up
At a guess you have lexus lights, they do not seal properly allowing water to run down
This is what happened to me
tubbe2
PostPosted: Wed Aug 17, 2011 6:18 am Up
I had the same problem - 2 of the 3 black plastic caps/plugs had deteriorated, and wasn't sealing at all. Instead of buying new plastic caps, I just took some marine grease and filled a lot of it on the caps, and put it back in. Seemed to seal it good enough. Haven't checked for water since though Razz
2002 Peugeot 206 GTi 2.0 16v 137Bhp
tamz
PostPosted: Wed Aug 17, 2011 10:53 am Up
am sure this section is for 206 problems ,
thanks every1 i will check out they suggestions Very Happy
macj
PostPosted: Wed Aug 17, 2011 11:28 am Up
If your a pimp... your prostitute needs emptying Laughing
tamz
PostPosted: Sat Aug 20, 2011 4:30 am Up
[quote="Addaz"]At a guess you have lexus lights, they do not seal properly allowing water to run down
This is what happened to me[/q
problem solved , thanks Very Happy Very Happy
