Latest: Beduff1977
Overall: 17134
Online Now [840]:
Visitors: 838
Members: 1
Today: 13383
Total: 107118897
Forums › The Car › 206 Problems › Airbag Light
Airbag Light
Tam80
PostPosted: Tue Aug 16, 2011 2:05 pm Up
started car earlier and the airbag light come on..nothing has been touched..any ideas ?
whats a good code reader for the 206 ?
cheers Thumb Up
(V) 99 GT/GTI/206
206/GT/GTI
JE_180
PostPosted: Tue Aug 16, 2011 2:09 pm Up
I had one on mine a few weeks ago, was a loose connection under the seat for the driver seat airbag. CD-530D used this one on my car on sunday as it was throwing up a anti pollution light after I fiddled with the exhaust system.. and it worked fine cgi.ebay.co.uk/ws/eBay...2565wt_905
PostPosted: Tue Aug 16, 2011 3:57 pm Up
That code reader aint gonna scan an airbag fault code Wink
Tam80
PostPosted: Wed Aug 17, 2011 12:15 pm Up
[/img]
checked all the wires under the seats..all seem ok..apart from this plug hanging down...cant see anywhere for it to go...any ideas peeps or should this just hang like this ?
cheers Thumb Up
206/GT/GTI
Tam80
PostPosted: Wed Aug 17, 2011 1:08 pm Up
forgot to mention...only noticed this from yesterday bout the same time as the airbag light has come on....when i start the car..i hear beep beep beep
dunno if this is connected or not
206/GT/GTI
gazza82
PostPosted: Wed Aug 17, 2011 2:18 pm Up
Without getting it properly diagnosed, you will be clutching at straws. A likely candidate though is the "squib" behind the steering wheel. This "fires" the airbag and can just die. Our local Pug/Citroen specialist used a Snapon kit, but some older cars may need to be read with the proper Lexia software as they are non-standard diag systems before Sept 2001 for Petrol, and Sept 2004 for Diesel.
Lucky you don't have a multiplex .. the part was about three times the cost of the pre-mux when I changed ours a few years ago ... nearly £100! (that's the mux version)
PostPosted: Wed Aug 17, 2011 3:14 pm Up
Tam80 wrote:
[/img]
cheers Thumb Up
White plug is for the drivers seatbelt warning light, not fitted to all 206's so dont worry about the white plug Wink
Tam80
PostPosted: Fri Aug 19, 2011 11:48 am Up
okies cheers again guys Thumb Up
206/GT/GTI
phuzee
PostPosted: Sun Aug 28, 2011 12:25 pm Up
Alright bought my 206 y reg with the airbag light on (non flashing) but after replacing the passenger side wing which had a bump on it, seemed to have cured the problem with it for a quite awhile. noticed today it has come back on but its flashing now when i turn the car of n on it goes off but then come back on after awhile? does anybody no what could be causing this ??
Thankss
phuzee
