Latest: Beduff1977
Overall: 17134
Online Now [154]:
Visitors: 153
Today: 1732
Total: 107107290
Forums › The Car › 206 Talk › multi-display on pre-plexed?
karimali831
PostPosted: Tue Aug 23, 2011 3:34 pm Up
Attempted to paint my interior dash but now it's f*** ugly and red is just awful anyway, wish I stayed away from it. I have got a replacement but the clock surround cover is plexed, wider than my other one, it fits well but I am using that mini clock which is designed for the pre-plexed clock surround. It doesn't look right that small clock with the display surround.
So my question is can I use plexed multi-function display ? I have checked connection and it is 6 pin.
Thanks Very Happy
EDIT. What can I use and what can't I use... 6 pin connection.
206 GTI 180
Antknee
PostPosted: Tue Aug 23, 2011 3:43 pm Up
The connector on the clock is a PPT20 connector, the others are PPT30 and PPT40, i think the PPT20 can be wired up somehow and a temperature sensor put in the passenger side wingmirror
PostPosted: Tue Aug 23, 2011 3:46 pm Up
PPT 20 is the little clock ant Wink the one he has
Is it a PPt 30 or PPT 40.. single line or double line?
PostPosted: Tue Aug 23, 2011 3:48 pm Up
i changed my ( ppt20 ) ....
to this.......
using this guide.... www.206info.co.uk/Foru...t=237.html
karimali831
PostPosted: Tue Aug 23, 2011 3:52 pm Up
3 pin 1 line, 3 pin line below.
so I can only have clock?
206 GTI 180
PostPosted: Tue Aug 23, 2011 3:53 pm Up
to this.......
Snap Wink mine was also a PPT40 (MUX) installed to a perplex.
PostPosted: Tue Aug 23, 2011 3:54 pm Up
You van have any if you get the connector with the new on and spend a little time wiring Wink
karimali831
Cheers... I will follow the guide! Smile
206 GTI 180
karimali831
PostPosted: Tue Aug 23, 2011 3:59 pm Up
Pretty straightforward but how I get the PP40 connector Very Happy
206 GTI 180
PostPosted: Tue Aug 23, 2011 4:01 pm Up
If it's from a Scrapyard. Cut it Wink give yourself as much spare wire as poss. If eBay. Make sure has connector Wink
PostPosted: Tue Aug 23, 2011 4:11 pm Up
Also If buying from a breakers on eBay they sometimes can cut a bit of cable off with it if you ask,
Done done it twice off eBay now Smile
karimali831
PostPosted: Tue Aug 23, 2011 4:14 pm Up
Yeah will need to ask for this because no listing mentions connections are included. Anyone have spare here?
206 GTI 180
Antknee
PostPosted: Tue Aug 23, 2011 4:27 pm Up
i thought thats what he meant he had Laughing
PostPosted: Tue Aug 23, 2011 4:28 pm Up
Your first post is confusing Wink get off your sugar high you wine gum junkie Wink
Antknee
PostPosted: Tue Aug 23, 2011 4:32 pm Up
iv just had a whole bag of haribo supermix and a whole bag of haribo strawbs, washed down with Corona, FML im in work at 10am!!
