Online Now [554]:
Visitors: 553
Today: 45857
Total: 105088176
Forums › The Car › 206 Talk › Headlight wireing fix
devildriverxii
PostPosted: Tue Aug 30, 2011 12:32 am Up
Basically (Hope I got this in the right) I started with H4 frosted, then I but the connector off to wire up some Angels.
But now I have a set of H7 crystals to go in and I need to add the correct connector to do so, bit I'm not sure what I'm buying, any one know =) a link would be amazing Smile
I did a search cause I know there are a million and one threads on lights, but I didn't find an answer.
2002 1.6 5dr Black Edition.
iainlovatt
PostPosted: Tue Aug 30, 2011 2:04 am Up
Its a lot of hard work just to put crystals in the car!! I gave up, you need relays and specif H4>H7 connections to be made up!
(My Garage)
PostPosted: Tue Aug 30, 2011 2:14 am Up
If you look where the h4 plug is there a h7 one clipped down at the bottom? (may even be loose).
If you do all you need is to use that connector and get a pre plex headlight stalk and it will work Smile
May be able to get you one tomorrow if you need it.
PostPosted: Tue Aug 30, 2011 2:33 am Up
Need to be the DOUBLE optic type pre plex headlamp stalk Wink
PostPosted: Tue Aug 30, 2011 2:37 am Up
Whoops I know forgot to say Laughing
Yeah needs to be off one with crystals as standard
PostPosted: Tue Aug 30, 2011 2:41 am Up
Frosted to crystals aint hard, why do people make out its such a ball ache with w**ky adaptor looms & relays Rolling Eyes
Non plex =
Fit the grey H7 connector plugs ( if not already hidden factory fitted ) & change the headlamp stalk to double optic spec.
Multiplex =
Fit the grey H7 connector plugs ( if not already hidden factory fitted ) & change the headlamp setting in the BSI configuration set up from single optic to double optic.
devildriverxii
PostPosted: Tue Aug 30, 2011 11:10 am Up
Cheers for that. I'll have a look to see if I have that hidden clip thing, though i doubt it.
I did buy one of those modified stalks that Lee is selling, that I use with my Angels, is that what you mean?
Edit: Also there is nothing hanging or attached.
Can't I just buy the connector from halfrauds or something?
PostPosted: Tue Aug 30, 2011 11:41 am Up
That stalk will work fine with crystals Smile
Just buy the H7 plugs from Peugeot, cheap enough Smile
devildriverxii
PostPosted: Tue Aug 30, 2011 1:12 pm Up
Awesome Smile half way there
One more Question, how do I order from Peugeot
Walk in the store and ask Laughing
devildriverxii
PostPosted: Tue Aug 30, 2011 1:16 pm Up
Ah right Smile I'll do that then.
PostPosted: Tue Aug 30, 2011 1:17 pm Up
Never heard of them
devildriverxii
PostPosted: Tue Aug 30, 2011 1:19 pm Up
Yeah I'm not going to bother with them, website looks a bit naff as well.
PostPosted: Tue Aug 30, 2011 3:04 pm Up
Walk in to any Peugeot / Citroen main dealer, go up to the parts counter & speak to the person serving.
You have the parts numbers, you just want to order the parts.
devildriverxii
PostPosted: Tue Aug 30, 2011 5:17 pm Up
Cheers Smile
