Posted: Sun Sep 04, 2011 6:41 am |
Decided to try and fit my black masked fog lights this morning, went to fit the drivers side first and found the easiest way was to remove the inner arch lining so did that then removed the bolt and wiring but , could not remove the 2 prongs that slot into the front bumper due to the washer bottle, any ideas how it can be removed without cutting them off?
Posted: Sun Sep 04, 2011 6:44 am |
undo the bolt for the bumper only way ive seen to get drivers off. passenger one is easy to take off though.
Posted: Sun Sep 04, 2011 6:46 am |
Posted: Sun Sep 04, 2011 6:47 am |
you mean to allow that side of the bumper to come away from the body to allow room for the fog to pull out?
Posted: Sun Sep 04, 2011 6:50 am |
MattyP wrote: |
you mean to allow that side of the bumper to come away from the body to allow room for the fog to pull out? | yes mate i found that to be easier way. but just my opinion.
AshH wrote: |
http://www.206info.co.uk/Forums/viewtopic/t=26067/highlight=removing+fogs.html
May help. They say you can get your head in and see proppa then! Doesnt say you need to take anythink else off just may take some time! |
cheers AshH, looks like I will have to remove the bumper
i took the washer bottle out of the way well i unbolted it to give leverage
