Online Now [52]:
Visitors: 51
Today: 17782
Total: 104927348
Forums › The Car › 206 Problems › Engine diagnostics warning light
KingKen
PostPosted: Tue Sep 13, 2011 7:19 am Up
Earlier my Engine diagnostics warning light came on while i was driving and the car seemed to lose power so i drove home, left it for a while, then started it again and the light didnt come on. Anyone else experienced this and be able to shed some light on what i should do?
Big_Rich180
PostPosted: Tue Sep 13, 2011 7:25 am Up
Never had this myself but I would get a diagnostic done to see if there is anything wrong.
Also it could help people if you put the spec of your car down.
PostPosted: Tue Sep 13, 2011 7:57 am Up
p**sing in to the wind until you get it scanned for fault codes.
Need year & fuel type to see if its EOBD compatible ( cheap to scan )
KingKen
Its a 03 plate 206 Quiksilver 1.4 8v and its done around 73k
PostPosted: Tue Sep 13, 2011 7:59 am Up
EOBD then, diagnostic socket is behind the flap to the right of the drivers knee.
Easy / cheap to scan with the right tool, most garages / diy mechanics can scan an EOBD car like this.
Also: Timing belt is every 80k miles or 5 years whichever comes FIRST on your TU3 engine Wink
KingKen
PostPosted: Tue Sep 13, 2011 8:11 am Up
thanks alot, i had the oil changed and a new oil filter a few weeks ago, and the mechanic said i needed a new timing belt, could this be the cause? and it has never been changed
thanks
PostPosted: Tue Sep 13, 2011 8:15 am Up
Nope, wont be the cause of the diagnostic warning light coming on.
Scanning this 206 isnt a problem as it's EOBD, until you read the fault codes its pure guess work BUT if the diagnostic light isnt on now while driving it will just be a stored code so not life & death.
Also get the timing belt replaced as the earliest opportunity.
KingKen
PostPosted: Tue Sep 13, 2011 8:26 am Up
ok he gave me a price for it so i will get it done soon as, and the light has now gone but i will still get it scanned, many thanks Smile
Lewis
PostPosted: Tue Sep 13, 2011 9:06 am Up
mine did this when the coilpack and fuel injectors went Smile
Tivoli LX 1.1
Black GTI 180
White VXR Burg
muzzy78
PostPosted: Tue Sep 13, 2011 10:10 am Up
Mine had this problem just a week ago so could be this
deanparkr
PostPosted: Tue Sep 13, 2011 11:58 am Up
A few years ago the random illumination of the engine diag light turned out to ne a faulty injector in my case.
2002 1.4LX
