Latest: S2cgm
Overall: 17178
Online Now [332]:
Visitors: 331
Today: 29493
Total: 137179284
Forums › The Car › 206 Talk › Wheel Bolts
Wheel Bolts
lenbt
PostPosted: Wed Sep 14, 2011 2:41 pm Up
Quick question,
are all original peugeot wheel bolts interchangeable?
as in, can I use 205 bolts on my 206?
thanks
PostPosted: Wed Sep 14, 2011 2:48 pm Up
No
PostPosted: Wed Sep 14, 2011 2:54 pm Up
are you sure Lee?
i though 205 bolts and 206 bolts are the same?
PostPosted: Wed Sep 14, 2011 2:58 pm Up
I've used alloy bolts from a 206 to put 205 wheels on and they were fine, dunno if that helps
PostPosted: Wed Sep 14, 2011 3:02 pm Up
Offset is different on the 205, so if you are using the 206 alloys with 205 bolts, the bolts won't go into the hub far enough
EDIT: scrap that, which bolts you talking about?
205 is fitted with 33mm, 38mm and 52.6mm and 65.5mm
PostPosted: Thu Sep 15, 2011 3:11 am Up
that makes more sense now; i know 205 has 33 and 38 bolts (which should be interchanagable with 206's one)
didn't know they got 52 and 65 one Laughing
lenbt
PostPosted: Fri Sep 16, 2011 9:31 am Up
Hmm, I'll have to look out for some 206 ones then. seems simpler.
PostPosted: Fri Sep 16, 2011 10:01 am Up
There cheap enough brand new from any Peugeot main dealer.
