Latest: Beduff1977
Overall: 17134
Online Now [639]:
Visitors: 638
Today: 19555
Total: 108835597
Forums › The Car › 206 Problems › Engine cut out when slowing down
LeeUK
PostPosted: Sun Sep 18, 2011 2:03 am Up
Hi, over the last few months my engine randomly cuts out when slowing down for a roundabout, traffic lights, etc, and the steering becomes near impossible. (Not sure if it is the steering lock engaging or the loss of power steering.)
Engine always starts again with no problems. Even with the car still moving.
This problem doesn't happen every day. Some times it is fine for days. Other times it can happen 2 or 3 times in a day.
Anyone know what is causing this and the possible solution?
My 206 is a 2001 1.4i petrol GLX with 52K miles.
Very Happy
2001 206 1.4i GLX
2001 Megane 1.6i Dynamique 16V
2008 207 1.4 HDI
2014 Focus 1.6 TDCI Titanium Nav
2020 Jaguar E-PACE Chequered Flag D150 AWD + 2002 Ford Focus 1.6 Ghia run-a-bout
leigh_boy
PostPosted: Sun Sep 18, 2011 2:09 am Up
Sounds to me like you have either a comon problem with the Air idle control valve, ( look it up will just need a clean)
or you have an air leak
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Sun Sep 18, 2011 3:10 am Up
If it will continue to run with the throttle applied then I'd go for the idle control valve too.
Ash
PostPosted: Sun Sep 18, 2011 4:51 am Up
Very Happy
Loss of Power Steering.. the lock won't engage with the key in the ignition.
As said, clean the Idle Control Valve.. There is a guide on here. Search.
