Latest: tebas93089
Overall: 17179
Online Now [159]:
Visitors: 157
Bots: 2
Today: 59370
Total: 137830907
Forums › The Car › 206 Talk › Peugeot 206 CC
Peugeot 206 CC
welsh_ben
PostPosted: Thu Aug 11, 2011 5:49 am Up
Hey guys just wondering if the peugeot 206 CC has a spare cage carrier on it? its my gfs car and i cant get hold of her and trying to find out if its got one to hold a spare wheel as shes only got the tyre inflator in a can stuff
cheers
Ben
hello
welsh_ben
PostPosted: Thu Aug 11, 2011 5:50 am Up
nvm just been asnwered by fatboyslim in the chatbox
The answer was no
thanks
hello
Abzynthe
PostPosted: Thu Aug 11, 2011 5:51 am Up
East Area Rep - Abzynthe
Just in case for future reference Smile
The boot is great when the top is up as it is so big and roomy, but very very small when the top is down. It is also not big enought to accomodate a spare wheel but there is a foam kit which will repair the tyre and get you to a garage to get it repaired.
Taken from www.ciao.co.uk/Peugeot...ew_5507520
welsh_ben
PostPosted: Thu Aug 11, 2011 5:54 am Up
yea shes got that can stuff but i dont trust it,there is enough room for a space saver wheel in the boot though
hello
fatboyslim
PostPosted: Thu Aug 11, 2011 6:12 am Up
Not entirely true
You can fit a space saver in the boot,takes up a bit of room though and you'll need to strap it down so it doesn't slide sbout,but put it in face down and you can keep a first aid kit and umbrella in the wheel dish
From what I've read the CC only had a spare as an optional extra
The cans are ok for normal punctures but anything over 5mm you can just about forget it
Also a lot of places are reluctant to fix tyres treated with the sealing goop and will recommend you get a new tyre, I worked at Kwik-fit a few years ago and we were told that we couldn't repair sealed tyres so the customer would need a new one ( after all how do you find a hole that's been sealed??)
Yes I own a CC and I'm neither gay or a hairdresser!!
glenpring
PostPosted: Thu Aug 11, 2011 6:30 am Up
can you put a cage under the car like a normal 206 hatchback?
PostPosted: Thu Aug 11, 2011 8:30 am Up
Apart from turning a potentially repairable tyre in to a scrap one Wink
fatboyslim
PostPosted: Thu Aug 11, 2011 9:06 am Up
It does actually say in the owners handbook that 'after using the sealent the tyre will need to be replaced'
As I said in my post above...
Quote::
'...a lot of places are reluctant to fix tyres treated with the sealing goop and will recommend you get a new tyre, I worked at Kwik-fit a few years ago and we were told that we couldn't repair sealed tyres so the customer would need a new one (after all how do you find a hole that's been sealed??)'
That's why the first thing I bought was a space-saver
craigdmjv
PostPosted: Thu Aug 11, 2011 11:07 am Up
it comes with a little can or tyre weld in the grey boxes in the boot
welsh_ben
PostPosted: Thu Sep 22, 2011 4:13 am Up
another problem if you can help...exhaust is now banging
had a look under and it looks like the metal "straps" which hold in in place have snapped off and gone, can these be replaced by local car parts place or does it need to be welded in place?
rather urgent if this could be answered please Smile
hello
welsh_ben
PostPosted: Thu Sep 22, 2011 4:24 am Up
just found out need to buy a new back box....surly i can just get a welder and weld a bracket back onto the backbox?
ben
hello
welsh_ben
*new backbox due to the bracket snapping
hello
gazza82
PostPosted: Thu Sep 22, 2011 4:31 am Up
Probably not. The CC has strengthening bars which attach to a box-like structure underneath the boot floor. That's exactly where the spare would need to go.
welsh_ben
PostPosted: Thu Sep 22, 2011 4:54 am Up
Cheers Gazza but that was sorted
hello
fatboyslim
PostPosted: Thu Sep 22, 2011 5:15 am Up
ben
You probably could or get a couple of clamp on repair hangers like this
CLICK ME but to be perfectly honest a new back box would be the best option
I know the back box for my 1.6 CC is available from ebay for around £50 including a new clamp and rubbers,they're quite easy to replace if you don't mind scrabbling about under the car
