Latest: tbafonso
Overall: 17130
Online Now [127]:
Visitors: 126
Today: 10867
Total: 102392550
Forums › The Car › 206 Talk › Fitting parcel-shelf speakers
PostPosted: Mon Oct 03, 2011 11:54 am Up
Are there cables near the boot to connect a pair of oval
speakers in the parcel-shelf or is dissasembly required of the panels
to pick-off the speaker lines from the HU?
It's a 3-door...
PostPosted: Mon Oct 03, 2011 11:55 am Up
6x9's are shocking sound quality. Fit some decent components
You need to run the wires via a amp ideally, if not just piggy back the rear speakers
PostPosted: Mon Oct 03, 2011 11:59 am Up
1) There are no rear speakers in there at the moment.
2) I now what you mean but it's fine for my purposes as I regularly
use 15KW setups for work so.. Twisted Evil
greg.mitchell350
depends how you want to set it up, as Lee said, people generally piggy back of the rear speakers. if you want a good sounds, put good componants in your front door, up rated tweeters on the a-pillar and a sub in the boot, will give the best sound possible
206 enthusiast
PostPosted: Mon Oct 03, 2011 12:09 pm Up
So can I get to the cables from the boot or will the panels, seatbelts etc have to come-off?
Lowercase
PostPosted: Mon Oct 03, 2011 12:18 pm Up
why bother? may aswell wear your glasses backwards for all the good they will do.
greg.mitchell350
PostPosted: Mon Oct 03, 2011 12:29 pm Up
panels will need to come of to get to the speakers. if i remember right that means the rear seats coming out as well
206 enthusiast
PostPosted: Mon Oct 03, 2011 12:51 pm Up
Cheers but I think I have a pretty good idea regarding 'what good they will do' and that is not what I'm asking anyway.
P.S. I don't wear glasses, only ear-plugs (read the thread).
Yes its seats, belts, panels and window seal for the speakers but I only want to connect to the cables and fit on the shelf instead.
PostPosted: Mon Oct 03, 2011 12:54 pm Up
Why not just get a bass tube?
PostPosted: Mon Oct 03, 2011 12:56 pm Up
Amp needed and I want the full range for the people sitting at the back..
Bass tubes have them built-in, like the OEM one
PostPosted: Mon Oct 03, 2011 12:58 pm Up
That's why I'm bothering with the whole thing tbh..
