Latest: Beduff1977
Overall: 17134
Online Now [865]:
Visitors: 864
Today: 76861
Total: 107066831
Forums › The Car › 206 Problems › 180 Head removal
180 Head removal
PugGti180
PostPosted: Fri Oct 07, 2011 7:24 am Up
Can anyone help me with a 'how to' on removing the head of my 180? Timing belt just snapped at only 38000mls!!! so i'm wanting to do a bit of the removal myself to keep the labour costs down. Cheers guys Smile
Mattie-RS
PostPosted: Fri Oct 07, 2011 8:40 am Up
Yeaa good luck with that! Laughing
L5_UKS
PostPosted: Fri Oct 07, 2011 8:44 am Up
As above unless you know what your doing I would say leave well alone and take to someone who knows what there doing, you could end up doing more harm than good.
PostPosted: Fri Oct 07, 2011 8:45 am Up
Timing belts also have a time limit on them Wink
PostPosted: Fri Oct 07, 2011 9:46 am Up
PugGti180
PostPosted: Fri Oct 07, 2011 10:31 am Up
yes haha so they do Lol that's cool then I'll just leave it to the pro's Wink cheers for the help.
PostPosted: Fri Oct 07, 2011 10:40 am Up
In all fairness, if it's already f****d...you can't make it much worse
Schumi
PostPosted: Fri Oct 07, 2011 11:42 am Up
Lee.
Did I ask you which program o catalog is this ? Very Happy
2005 206 RC RED
PostPosted: Fri Oct 07, 2011 11:44 am Up
Schumi wrote:
Lee.
It's servicebox, online Smile
PostPosted: Fri Oct 07, 2011 11:49 am Up
better to check the bottom too just in case the snapped valve drops.....
80K miles or 5 yr for belt.
kit325
PostPosted: Fri Oct 07, 2011 12:32 pm Up
Well, a nice 2nd hand engine might be better value if too much damage been done when the belt snapped.
kit
mjrimmer
PostPosted: Fri Oct 07, 2011 5:48 pm Up
knob!
206 gti 180
mjrimmer
PostPosted: Fri Oct 07, 2011 5:52 pm Up
my previous statment may be premature....what year is your car?
206 gti 180
PostPosted: Sat Oct 08, 2011 12:51 am Up
I do think that just replacing the engine could work out at a similar price...
PostPosted: Sat Oct 08, 2011 2:53 am Up
Plus you'd need to get the timing belt changed on that too if it hadn't been done
