Latest: Beduff1977
Overall: 17134
Online Now [564]:
Visitors: 563
Today: 235227
Total: 110089459
Forums › The Car › 206 Talk › Remove rear light
Remove rear light
matty_riddell
PostPosted: Mon Oct 10, 2011 11:23 am Up
I have searched but i couldnt find a thread that shows pictures or video of how to remove the rear lights.. please couild someone tell me.. pictures preferred thanks.. or direct me to a post.. thanks Smile
hi
How to section - dismantling a 206
PostPosted: Mon Oct 10, 2011 11:24 am Up
Pull the carpet back in the boot, 10mm socket on the bolt and it slides out. Simples.
PostPosted: Mon Oct 10, 2011 11:25 am Up
Actually I think the 206 has a bolt you can unscrew by hand thinking about it.
PostPosted: Mon Oct 10, 2011 11:30 am Up
It's similar to a winged nut. Sometimes a pair of pliers helps as they can be tight if they have been on a while, or over tightened in the past.
PostPosted: Mon Oct 10, 2011 11:31 am Up
17/19mm socket
PostPosted: Mon Oct 10, 2011 12:05 pm Up
It's doesn't just slide out, there is a little locking tab that needs pulling down too.
PostPosted: Mon Oct 10, 2011 12:50 pm Up
I agree with what all the guys said Smile
