Posted: Mon Oct 10, 2011 11:48 am |
is it possible / ok to power up car without the engine and engine loom?
have a few electrical things i want to do in car and need power in the car.
thanks ben ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
| | ![](images/spacer.gif) |
Posted: Mon Oct 10, 2011 11:51 am |
All you need is a battery and connect it up ![Laughing Laughing](images/smiles/icon_lol.gif)
Posted: Mon Oct 10, 2011 11:56 am |
you will need to insulate the starter and alternator cables
Posted: Mon Oct 10, 2011 11:57 am |
Lee wrote: |
All you need is a battery and connect it up ![Laughing Laughing](images/smiles/icon_lol.gif) |
well i know that
was interested if it was ok to do.
macj wrote: |
you will need to insulate the starter and alternator cables |
good point thanks ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
Posted: Mon Oct 10, 2011 12:04 pm |
Won't the fuel pump build up pressure in the fuel hose? Are the injectors still fitted?
Posted: Mon Oct 10, 2011 12:09 pm |
Edward wrote: |
Won't the fuel pump build up pressure in the fuel hose? Are the injectors still fitted? |
no engine or the loom for engine,
the fuel pipe is just laying in bay atm,
Posted: Mon Oct 10, 2011 12:11 pm |
I would unplug the pump under the rear seat access to be safe
Posted: Mon Oct 10, 2011 12:21 pm |
Fuel pump won't prime if he just has it on accessory and not ignition, or just d/c the pump
Posted: Mon Oct 10, 2011 12:23 pm |
, just the fuel pump i had forgot about
cheers guys ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
