Posted: Thu Oct 13, 2011 8:02 am |
Drivers side works ok just the passenger side, ive tried poking it and still nothin.
Posted: Thu Oct 13, 2011 8:07 am |
Checked the pipes aren't blocked or popped off on the underside of the bonnet?
Posted: Thu Oct 13, 2011 8:23 am |
yea all seems fine there
Posted: Thu Oct 13, 2011 8:32 am |
It will be the nozzle, needs replacing. Poking it can clear a small blockage, but if its anything bigger, just pushes the crap right into it.
Posted: Thu Oct 13, 2011 8:46 am |
so i need new washer jets??
Posted: Thu Oct 13, 2011 8:49 am |
could it still pass MOT with 1 working?
Posted: Thu Oct 13, 2011 8:51 am |
Have you tried taking it off and blowing through it to make sure it's clear?
Posted: Thu Oct 13, 2011 10:20 am |
you'll fail an mot with only one working
Posted: Thu Oct 13, 2011 10:23 am |
ExoVyper wrote: |
you'll fail an mot with only one working |
Its just passed
Posted: Thu Oct 13, 2011 10:24 am |
it shouldn't have as it'll usually get put down with inadequate cover or something :L
Posted: Thu Oct 13, 2011 12:50 pm |
acotton21 wrote: |
ExoVyper wrote: |
Its just passed  |
That should be a concern. If they've missed something as simple to check as a washer jet, what other safety items have they missed, which are more difficult for an owner to check themselves? Or are you just happy it passed and that will do?
Posted: Thu Oct 13, 2011 12:59 pm |
paul_c wrote: |
acotton21 wrote: |
ExoVyper wrote: |
Its just passed  |
That should be a concern. If they've missed something as simple to check as a washer jet, what other safety items have they missed, which are more difficult for an owner to check themselves? Or are you just happy it passed and that will do? |
i did say ive had problems with it as it went in
Posted: Thu Oct 13, 2011 1:14 pm |
That isn't right surely lol, mine failed because of that
Posted: Thu Oct 13, 2011 1:28 pm |
think because 1 worked and the other worked a little bit
Posted: Thu Oct 13, 2011 1:31 pm |
yeahh mine did but still went down as insufficient fluid on the windscreen or something lol
