Latest: sparrowdclxvi
Overall: 17139
Online Now [68]:
Visitors: 67
Today: 20651
Total: 112533296
Forums › The Car › 206 Problems › Passenger seat will not slid forward when tipped forward
rich42
PostPosted: Sat Oct 29, 2011 6:40 am Up
The car is a 206CC 2001 2L. The passenger seat will not slid forward to allow access into the back, when the seat is tipped forwards. I found a 50mm long pin with a flat top on the floor also, i guess it may be involved but I can't see where.
The seat slid mechansim works OK from the front handle.
If I have to take the seat out to fix, can I safley disconnect the airbag control cable?
Regards, Rich
Deckchair5
PostPosted: Sat Oct 29, 2011 8:25 am Up
You may not need to take the seat out if the top hat type cap and bolt have detached. This is how they should look
There's a "How to" guide on here if you search around
