Latest: tbafonso
Overall: 17130
Online Now [361]:
Visitors: 360
Today: 14343
Total: 102939961
Forums › The Car › 206 Problems › Speedo and dash lights not working
willriseley
PostPosted: Tue Nov 22, 2011 11:44 am Up
hey guys the misses 206, X plate 1.4 has none of the lights on the dash or instrument panel working, I have checked the fuses and there fine its saying a 5amp for the interior lights, all other fuses look fine so can it be all the bulbs have blown? spent ages looking through the net trying to find out what it is???
will
PostPosted: Tue Nov 22, 2011 11:47 am Up
Warning lights or the illumination?
Not something stupid like moved the dimmer wheel setting down by accident?
willriseley
PostPosted: Tue Nov 22, 2011 12:32 pm Up
the lights to show you what speed,revs, ptrol and wotnot completly out, fuse is ok, tried moving all dimmer thingies as well and nothing ? managed to get some bulbs from another 206 at a yard today so maybe worh a try? can you buy the bulbs new?
will
PostPosted: Tue Nov 22, 2011 1:17 pm Up
Yes.
Any Peugeot / Citroen main dealer parts dept OR local motor factors.
Even Halfords will sell them.
willriseley
PostPosted: Tue Nov 22, 2011 1:20 pm Up
really? think it could be that they have ALL gone then or are they like xmas likes where if one has gone there all out like a circuit thing?
Any other ideas on it?
will
flynn763
PostPosted: Sat Nov 26, 2011 5:58 am Up
Take a bulb out and look very closely at the filament inside the bulb, you may be able to spot whether or not it has blown. Change one bulb and see if it works. Its unusual for several bulbs to go at the same time but you never know, these things do happen sometimes.
Hasta la vista baby!
devildriverxii
PostPosted: Sat Nov 26, 2011 10:39 am Up
But if someone doesn't know what they're doing, they probably just kept putting it off.
Just change all the bulbs. I had to do this recently with my x-reg, it's fairly easy, but I found leaving 2 different brands of bulbs in, also some being old, some new, it left an uneven brightness across the dials.
Get hold of a pug dealer as said before, not sure on the price but if these are cheaper, get these, they worked fine for me, you just need to re-use your bulb holders
t5 bulbs
2002 1.6 5dr Black Edition.
willriseley
PostPosted: Sat Nov 26, 2011 7:11 pm Up
stupid question but do the bulbs come out of the holders easily?
will
