Posted: Fri Nov 25, 2011 9:40 am |
Couple months back my abs light decided to come on, it would come on and stay on, when I started the car it would stay on longer than normal but would then turn off, took it to my local garage and put it on their diagnostic machine but it didn't read an error code, anyway it has recently come back on again and is doing the same thing, any ideas?
Posted: Fri Nov 25, 2011 10:00 am |
abs sensor needs replacing maybe, happened on my hdi gti before i bought it, they replaced it problem gone.
i even got to keep the old sensor lol
Posted: Fri Nov 25, 2011 11:57 am |
Take it to a garage that has a decent code reader, not a ebay special
Posted: Fri Nov 25, 2011 5:15 pm |
It was a proper garage it went too
Posted: Sat Nov 26, 2011 4:32 am |
MattyP wrote: |
It was a proper garage it went too |
Doesnt sound like it if they couldnt even read a simple ABS fault code
Posted: Sat Nov 26, 2011 4:34 am |
MrBSI wrote: |
MattyP wrote: |
Doesnt sound like it if they couldnt even read a simple ABS fault code |
They'll be using a eBay special that only reads P codes
Posted: Sat Nov 26, 2011 4:35 am |
Bring back the old Bosch 2E ABS, flash the fault codes out on the dash lamp
Posted: Sat Nov 26, 2011 4:41 am |
Had to do that with a ford the other day because I didn't have the laptop with me
Then on a MX5 had to put a LED between B+ and FEN and count the flashes
Posted: Sat Nov 26, 2011 8:12 am |
Have you checked the trigger rings on the drivehshafts? Mine was cracked but the light only came on over 100mph (which is why it took so long to show itself)...after a re-start the light would switch itself off.
