Latest: Puggingalong
Overall: 17129
Online Now [281]:
Visitors: 280
Today: 33652
Total: 100955274
Forums › The Car › 206 Problems › ticking noise
ticking noise
Boydie
PostPosted: Tue Aug 09, 2011 6:54 am Up
my 1.4 hdi is making a loud ticking noise would it be the timing belt on its last legs
Gti 180
mattievrs
PostPosted: Tue Aug 09, 2011 7:28 am Up
could be anything mate! Can you be more specific? Ie where from,at what speed,etc etc
NO LONGER ACTIVE ON THE FORUM
MrrNoName
PostPosted: Tue Aug 09, 2011 9:10 am Up
why would you jump to the timing belt? if its been replaced at its intervals it will be fine, if it hasnt you should get it done regardless of whether the ticking is that or not Razz
could be the lifters? ive heard other people on here say that they create a loud ticking noise
KARIM
PostPosted: Tue Aug 09, 2011 9:28 am Up
My peugeot 1.4hdi is making the same sound also very loud id like to know what the problem is also, i was guessing towards the timming belt also as i dont really know if this has been changed in my car.
K666
mattievrs
PostPosted: Tue Aug 09, 2011 9:39 am Up
AGAIN MORE INFO NEEDED
Is it ticking from the top of the engine, side of the engine, bottom of the engine????
If you guys want help then give as much info as possible or you wont get the help needed as we dont have crystal balls!!
eddrj
PostPosted: Tue Aug 09, 2011 9:40 am Up
i know on my old 2.0 hdi that noise means crankshaft bottom pulley but not sure if its same common fault - loud ticking noise on the 1.4 hdi aswell.
Old car 2000/ 206 2.0 hdi.
Kersh
PostPosted: Tue Aug 09, 2011 9:45 am Up
voldemort voldemort vol voldey voldey voldey voldemort
Member number: 36
KARIM
PostPosted: Tue Aug 09, 2011 10:00 am Up
Im having my brake discs changed tomorrow by a garage my dads recommended to me and ill have them check this out and if they give me any information on what it is ill post back to you. I cant actually say where the sounds coming from as I dont have the car at the moment but once I do ill post again.
K666
KARIM
PostPosted: Fri Nov 25, 2011 10:19 am Up
I still have this problem... Changed the timming belt. The sound increases with speed or more accurate the faster i go the faster the ticking sound comes... Sounds as if coming from left side of engine area....
K666
KARIM
PostPosted: Fri Nov 25, 2011 3:51 pm Up
Sorry for posting again but really want some help as ro wether i should be driving this car as it is or something needs to be changed... Its just come back from mechanic twice had a service and fuel pump + all fuel lines changed... Also just done the timming belt... This car keeps costing me money but id rather fix it then spoil it....
Any help would be greatful.
Karim
K666
mjsroofing
PostPosted: Sun Nov 27, 2011 4:53 am Up
the bottom pulley is a comman problem, most people will agree this is the first port of call. remove the aux/fan belt and then run the engine ( for a short time ) see if the sounds changes.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
EmoStu
PostPosted: Sun Nov 27, 2011 5:22 am Up
Could be your auxilary belt? That's on the left side of my 1.6 engine, not sure about yours. Mine makes a slight ticking or taping noise in the cold
EmoStu
Peugeot 206 1.6 XSi Firedance
KARIM
PostPosted: Sun Nov 27, 2011 2:48 pm Up
Thanks for that mate will have to check that out..
Karim
K666
