Latest: tbafonso
Overall: 17130
Online Now [389]:
Visitors: 388
Today: 40999
Total: 102884828
Forums › The Car › 206 Talk › 1 fog light not working
s1mon
PostPosted: Tue Nov 29, 2011 11:35 am Up
hope someone can help me 1 of my fog light not working the driver side does not work i have checked the bulb and the plug and it still does not work can someone please help me
\"Understeer\" is when you hit the fence with the front of the car.\r\n\"Oversteer\" is when you hit the fence with the rear of the car.\r\n\"Horsepower\" is how fast you hit the fence.\r\n\"Torque\" i
PostPosted: Tue Nov 29, 2011 11:37 am Up
Don't worry about them. You don't need them.
Is it foggy in Skegness then?
Could be a fuse but not sure
PostPosted: Tue Nov 29, 2011 11:39 am Up
fuse? pretty sure each bulb got it's own fuse.
s1mon
PostPosted: Tue Nov 29, 2011 11:40 am Up
no is not foggy is there a picture of the fuse box diagram on here
PostPosted: Tue Nov 29, 2011 11:41 am Up
How'd you 'check' the bulb? If you just 'looked' at it & didn't light it up, I'd change it. Bulbs can look fine but actully be useless (a bit like blondes).
kakaruto
PostPosted: Tue Nov 29, 2011 11:42 am Up
Rolling On The Floor Laughing
2001 Y 206 1.4 LX Black
s1mon
PostPosted: Tue Nov 29, 2011 11:54 am Up
i put a new bulb in and notting
PostPosted: Tue Nov 29, 2011 12:01 pm Up
Nope, there wired in parallel of the same fuse Wink
PostPosted: Tue Nov 29, 2011 12:03 pm Up
If one of the front fogs is working then your wasting your time looking in the fuse box Wink
burnmw
PostPosted: Tue Nov 29, 2011 12:12 pm Up
I presume you aren't talking about rear fogs?
The day that Microsoft makes something that doesn\'t suck is the day that they start making vacuums.
PostPosted: Tue Nov 29, 2011 12:17 pm Up
There is only one fog on the rear.
It will be a connector or bulb holder issue
burnmw
PostPosted: Tue Nov 29, 2011 12:28 pm Up
Possibly not true, not sure about the 206 but the 306 has a space in both sides for the rear fog, but only the drivers side has a bulb. If you put a bulb in the passenger side holder it will work. I know quite a few people who have done this Thumb Up
fatboyslim
PostPosted: Tue Nov 29, 2011 12:32 pm Up
Nope 206 only has one fog light,it's in the centre of the lower rear bumper
Yes I own a CC and I'm neither gay or a hairdresser!!
burnmw
PostPosted: Tue Nov 29, 2011 12:36 pm Up
Good point... DOH!!! I'll go and sit in the corner and face the wall! Laughing
