Latest: Beduff1977
Overall: 17134
Online Now [539]:
Visitors: 538
Today: 77004
Total: 108709216
Forums › The Car › 206 Problems › 180 seats
180 seats
Boydie
PostPosted: Sat Dec 03, 2011 10:24 am Up
went 2 move my passenger seat back and it wont move..pulled bar up and wont move at all..its as if there is something blocking the seat from moving in the runner..the seat is pushed up as far as it can go so pretty much u are sitting on the dash!! cant even take the front seat bolts out as seat is covering them
anyone else had this problem or no whats wrong??
cheers
Gti 180
DavidPCoates
PostPosted: Sat Dec 03, 2011 10:45 am Up
Is it 3 or 5 door?
If I remember right, the runners are independent linked by the release handle, so i dont think its something in the runner or the seat would "crab" (move slightly on one side as the seat flexes).
Your gonna have to get under the seat with a torch, possibly disconnect the release bar from each of the runners (held with spring clip i think)and try to manuallly operate the slides until the seat is far enough back to get to the bolts to take the seat out.
On 3 dr, there is a memory mechanism at the rear of either or both rails, have a look at that, it may have jammed.
Dave Coates
Jamie1337
PostPosted: Sat Dec 03, 2011 10:50 am Up
Trade Rating: +37
get some wd40 on the main opperating parts first of all, pump the seat right up get underneath and try and see what exactly isnt releasing or is preventing it from moving!
Light Right Foot FTW!
shell-vt
PostPosted: Sat Dec 03, 2011 11:47 am Up
Trade Rating: +46
as above ...
york 16,3
Boydie
PostPosted: Sat Dec 03, 2011 11:56 am Up
DavidPCoates wrote:
Is it 3 or 5 door?
yea its a 3 door..so take the spring out and c what happens
Gti 180
PostPosted: Sat Dec 03, 2011 12:15 pm Up
First sit in the seat and rock back and forth, whilst lifting the bar. Repeat a few times. Mine likes to jam every now and then.
Boydie
PostPosted: Sat Dec 03, 2011 12:21 pm Up
been doing that but nothing seems to happen
Gti 180
PostPosted: Sat Dec 03, 2011 12:40 pm Up
Did you make sure the bolts were fully screwed in?
Boydie
PostPosted: Sat Dec 03, 2011 12:45 pm Up
yea fully tightened
Gti 180
PostPosted: Sat Dec 03, 2011 12:50 pm Up
Check for a little metal thing in between the runners. I dont know what it does, but something to do with locking the seats in position, sometimes sticks.
Boydie
PostPosted: Sun Dec 04, 2011 11:25 am Up
cant see the bit of metal it must b in the part of the runner thats under the seat
Gti 180
Ali_H
PostPosted: Sun Dec 04, 2011 11:43 am Up
Use some brute force, Pug fixed mine FOC in ten minutes.
kurtis wrote:
138Andy
PostPosted: Sun Dec 04, 2011 1:33 pm Up
get under it with a screwdriver and lift the release up, same s**t happened on mine it locked up when i moved it all the way forward
Boydie
PostPosted: Sun Dec 04, 2011 1:36 pm Up
the bit in the runner?
Gti 180
Boydie
did they say what the problem was
Gti 180
