Online Now [598]:
Visitors: 597
Today: 124659
Total: 106318779
Forums › The Car › 206 Problems › Offside Intermediate Drive Shaft Bearing/Joint
PUGPAUL
PostPosted: Sat Dec 03, 2011 1:30 pm Up
Offside Intermediate Drive Shaft Bearing/Joint?
ON THE RIGHT HAND SIDE OF THIS BEARING IS A CONVENTIONAL CONE SHAPE GAITER/BOOT; ON THE OTHER SIDE IS ANOTHER SHAFT GOING TO THE GEARBOX ~ my question is - does 'this' other side of the joint suppose to have a gaiter of some kind and grease packing over the ball bearings? Mine currently has NO gaiter or grease and three 'bone dry' rusty ball bearings have fallen out of the joint and there is no longer any drive to the o/s/f wheel !!!
If yes? ~ can a new intermediate bearing be purchased separately with grease and rubber boot; or do you have to buy a complete drive shaft?
Cheers in advance!
Peugeot 206 HDi (1.4cc) 'eco' - 2005
PUGPAUL
PostPosted: Sun Dec 04, 2011 12:02 pm Up
Can you buy an intermediate drive shaft bearing please?
(i.e. on its own)
cheers!
seen this complete: drive shaft
PostPosted: Sun Dec 04, 2011 12:16 pm Up
Does this help?
PUGPAUL
PostPosted: Mon Dec 05, 2011 4:42 pm Up
Edward wrote:
Does this help?
NICE PHOTO! ~ can you get the centre bearing on its own without the rest of the shaft though?
cheers!
Rob2859
PostPosted: Mon Dec 05, 2011 6:51 pm Up
Look on ebay. I assume so as you can get the outer joints separate they are not compete units in their own right like on 106's.
PUGPAUL
PostPosted: Tue Dec 06, 2011 4:25 pm Up
CAN'T see any on ebay separately. My local factor says that you can buy the outer separate but not the inner!
PUGPAUL
PostPosted: Mon Jan 23, 2012 11:51 am Up
Bought this complete: drive shaft
