Latest: tbafonso
Overall: 17130
Online Now [411]:
Visitors: 409
Members: 1
Today: 21558
Total: 102947170
Forums › The Car › 206 Problems › 206 CC blower motor
206 CC blower motor
andycooks19
PostPosted: Wed Dec 07, 2011 8:41 am Up
have a 206cc on an 02 plate with auto digital aircon. The blower is stuck on highest level so after much research am lead to believe the blower motor may need replacing. Is it possible to replace just the resistor on these systems or only the whole motor? GSF have both for sale resistor and motor thanks
pe
PostPosted: Wed Dec 07, 2011 9:55 am Up
I have a used motor in good condition. PM me if interested.
PostPosted: Wed Dec 07, 2011 12:31 pm Up
If the motor is at full blast only it suggest the motor is perfectly healthy. Sounds like the fan controller is at fault.
