Online Now [66]:
Visitors: 65
Today: 3059
Total: 106048933
Forums › The Car › 206 Problems › 206 gti rear beam
206 gti rear beam
andygriff
PostPosted: Sat Dec 10, 2011 2:19 pm Up
hi, i have just got a x reg 206 gti, there is a very loud knockin comein from the rear beam does it need a recon beam or can mine be repaired ???
thanks andy Very Happy
206gti
PostPosted: Sat Dec 10, 2011 2:27 pm Up
until you strip it down otherwise no one can tell
andygriff
PostPosted: Sat Dec 10, 2011 2:34 pm Up
ok thanks, i need it done asap where is the best place for a recon or new beam ?
206gti
PostPosted: Sat Dec 10, 2011 2:44 pm Up
www.sspengineering.co.uk/
PostPosted: Sat Dec 10, 2011 5:04 pm Up
Seabook wrote:
http://www.sspengineering.co.uk/
+1 Recomended.
Rob2859
PostPosted: Sat Dec 10, 2011 8:13 pm Up
Think lee still has a GTI axle.
PostPosted: Sun Dec 11, 2011 3:58 am Up
Could just be the anti roll bar that needs tightening or the damper bolts might be loose.
PostPosted: Sun Dec 11, 2011 4:07 am Up
I've got a few beams if you want a second hand one, would find out the issue first could be something more simple than you think
