Posted: Sat Dec 10, 2011 3:19 pm |
hi, i have just got a x reg 206 gti, there is a very loud knockin comein from the rear beam does it need a recon beam or can mine be repaired ???
thanks andy
Posted: Sat Dec 10, 2011 3:27 pm |
until you strip it down otherwise no one can tell
Posted: Sat Dec 10, 2011 3:34 pm |
ok thanks, i need it done asap where is the best place for a recon or new beam ?
Posted: Sat Dec 10, 2011 3:44 pm |
Posted: Sat Dec 10, 2011 6:04 pm |
| Seabook wrote: |
| http://www.sspengineering.co.uk/ |
+1 Recomended.
Posted: Sat Dec 10, 2011 9:13 pm |
Think lee still has a GTI axle.
Posted: Sun Dec 11, 2011 4:58 am |
Could just be the anti roll bar that needs tightening or the damper bolts might be loose.
Posted: Sun Dec 11, 2011 5:07 am |
I've got a few beams if you want a second hand one, would find out the issue first could be something more simple than you think
