Latest: tbafonso
Overall: 17130
Online Now [372]:
Visitors: 371
Today: 7938
Total: 104539776
Forums › The Car › 206 Problems › head gasket
head gasket
gavin86
PostPosted: Sun Dec 11, 2011 11:45 am Up
i think my head gasket has gone and im wondering how much it costs to fix roughly
thanks gavin
PostPosted: Sun Dec 11, 2011 11:50 am Up
No idea till you tell us which engine you have fitted.
gavin86
PostPosted: Sun Dec 11, 2011 11:52 am Up
iv got the 1.4 in it its a 2000 model its bog standard at the moment
thanks gavin
dumdum0910
PostPosted: Sun Dec 11, 2011 12:17 pm Up
you can go budget or expensive. budget just rip the head off replace gasket job done. expensive rip head off send it off to get skimmed and what not and replace gaskets
HDI90
well to do the job id say around 400 quid because you will need a new cambelt and water pump too
GTI 180
gavin86
PostPosted: Sun Dec 11, 2011 12:23 pm Up
ok thanks guys Smile
thanks gavin
PostPosted: Sun Dec 11, 2011 1:50 pm Up
When you have a headgasket problem you have to do the following:
1-Get the head cleaned,got it skimmed only IF it's in the bad shape,but some heads only needs cleaning and get the new gasket fitted.
2-Change the Cambelt (get a cambelt set which includes water pump).
3-Change the thermostat because it might be the cause of the headgasket problem you had.
4-get your radiator flushed and cleaned throughly,to make sure that your coolant cycle running in a perfect way.
5-Add antifreez,new oil,new oil filter and then you are ready,and Off you goooooooooo Very Happy
about the cost,I don't know how much,but when you wanna do something,do it right Very Happy
devotedsniper
PostPosted: Sun Dec 11, 2011 3:49 pm Up
Mine just cost me £440 including VAT (and a new dipstick....it snapped), that was for everything, head skimming, new cambelt, labour, a full check up in 500 mile.
Now a 2010 Renault Megane Coupe owner
PostPosted: Mon Dec 12, 2011 9:37 am Up
Could work out cheaper to just throw another TU3 in it, there's plenty of decent lumps around.
